"Unsent Messages" folder on main account
Postby ten13 » Thu 26 Dec, 2002 11:49 pm
Here's a question that I should have the answer for....
I had NS7 on an old computer, and, I believe, it had an "unsent messages" folder on my main email account.
When I loyally reloaded NS7 on the new computer (running XP, by the way), I see that there is no "unsent messages" folder on my main email account, but one under "Local Folders". When I do a "send message later" thing, they go to the one on the Local Folders.
Now, I realize that this isn't the end of the world, but I'd be curious to know if I should have an "unsent" folder on the main email account also. Do I have reload NS7 to bring it back up?
Any thoughts would be appreciated....
Jim
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.0.1) Gecko/20020823 Netscape/7.0 (nscd2)
ten13
Re: "Unsent Messages" folder on main account
Postby Fulvio » Fri 27 Dec, 2002 12:43 pm
ten13 wrote:Here's a question that I should have the answer for....
Jim
You are not the first one to be faked out by Netscape changing the name to Drafts. But, I sure do not have an unsent messages in local folders. You should select Drafts for the particular Account, in the Account Settings box.
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.0.2) Gecko/20021120 Netscape/7.01 (CK-DJGM-i.net)
Postby Ramona » Fri 27 Dec, 2002 5:19 pm
Hi ten13,
There is a workaround for creating an Unsent Messages Folder. Fulvio uses the Drafts folder, but I don't agree that "Drafts" should be used for your "Send Later" messages. The below script should be added to the user.js file, or the prefs.js file:
user_pref("mail.default_sendlater_uri","mailbox://<username>@<servername>/Unsent%20Messages");
<username> and <servername> as they appear on:
Edit | Mail & Newsgroups Account Settings | <account> | Server settings
Credit for this workaround goes to Jeroen Peters who first gave this answer on the Netscape 7 Newsgroup.
I can guarantee the workaround, as I just added the above script to my user.js file. I then composed a message offline, and selected Send Later. When I started Netscape the Unsent Messages folder was in my Main Account, and the unsent msg was there, waiting to be sent. WooHooooooo!
If you haven't created a user.js file and need help with the creation, post back.
Ramona :D
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.0.2) Gecko/20021120 Netscape/7.01 (CK-SillyDog)
Which File?
Postby ten13 » Fri 27 Dec, 2002 8:56 pm
Thanks for your imput on this "Unsent" issue I have. But it says to put that line in the "prefs.js" which NS 7 doesn't seem to have. It has A LOT of .js files, but none that are specifically "pref.js"
I tried that line in the "mailnews.js" file---didn't work. I was going to try the "mailnews-ns.js" file, but I figured I would just ask for a clarification here.
Thanks for your help, and looking forward to your replies...
Jim
ten13
OK...found it..
Postby ten13 » Sat 28 Dec, 2002 12:36 am
Unlike the older versions of NS, the pref.js file is a hidden file, and I had to go looking for it again.
Found it, added the new line, and IT WORKS!
Thanks to all, again!
ten13
Copy failed on save to unsent messages folder
Postby joc » Tue 01 Feb, 2005 4:41 am
Using NS7.1 and Win2000 SP2. After following the advice of how to get an "Unsent folder" created in my new NS7.1 account. I cannot do a "send later". The message I get is "unable to save your message to send it later. Please verify that your mail & newsgroups account settings are correct and try again". In the lower left hand corner of my screen it says "copy failed". Yes, i did do the "mail.default_sendlater_uri..." thing (using about:config) and set the values as follows "mailbox://<username>@pop-server.midsouth.rr.com/Unsent%20Messages. It still does not work. Needless to say this is quite frustrating. If anyone can help please do. I am serioulsy considering defecting to OUTLOOK
:? ... and I hate outlook.
joc
Postby Alice » Tue 01 Feb, 2005 7:54 am
Go back to about:config and right-click the mail.default_sendlater_uri entry and select "Reset" to get back to the original "default" setting. (You didn't mention it but, IF you also added the preference given above to a user.js file then you'll need to remove the entry from the user.js IN ADDITION TO resetting mail.default_sendlater_uri in about:config)
I use the default Unsent Messages folder under Local Folders, the few times I choose the "Send later" option so I can't speak from experience but.... If you really want the unsent messages folder moved, then reset the preference in about:config, modify it again and then exit and restart Netscape before attempting to use the "send later" option.
The default value of the mail.default_sendlater_uri entry is:
mailbox://nobody@Local%20Folders/Unsent%20Messages
your modified value should look similar to:
mailbox://<username>@<popmailservername>/Unsent%20Messages
Double-check your username and popmailservernames against what is given in Edit>Mail&newsgroup Account Settings> "mailaccount" > server settings.
And you might want to consider uninstalling Netscape 7.1 and upgrading to Netscape 7.2, if only for the bug fixes.
Post back if you need more help.
Postby joc » Tue 01 Feb, 2005 2:44 pm
Thaks you Alice for your quick reply. I tried exactly what you mentioned about the resetting the "mail.default_sendlater_uri", then changing it to point to my new server name. I still got the exact same message. I wouldn't mind upgrading to 7.2 if it won't cause further problems. I seem to remember attempting to go to 7.2 months and having horrendous problems with the being able to download email afterwards (might have bene a beta version, though). Do you know of any issues with migrating from 7.1 to 7.2? Also, is there any reason why I shouldn't go to thunderbird?
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0; .NET CLR 1.1.4322)
joc
Postby Fulvio » Tue 01 Feb, 2005 3:03 pm
The only issue that I know of, in "migrating" from 7.1 to 7.2 occurs when both versions are present and the same time, and used with the same profile.
I placed the word migrate in quote because absolutely nothing migrates. Netscape7.1 and 7.2 are made up of three parts. The program, which is removed when you uninstall from the Add/Remove. Only the plugins folder, and one or two other files are preserved. The GRE folder from Program File|Common File|GRE|GRE for each version., which should also be removed. And, the Profile which is left untouched by uninstalling. The Profile sit still, so there is no migration, although changes to the prefs.Js file can and should occur, when a new version is installed.
I have been using Netscape profiles for Mozilla, and viceversa, old and new, with no obvious problem, other than the Themes, as long as the original program is removed. You can have one or more profile per installation, but not the other way around.
And, contrary to the common fear, the profile information is kept intact, when a version is uninstalled.
I have Netscape7.2 with two profiles, which are radically different, as well as Thunderbird, also with two profiles. I am using Firefox1.0, one profile for now, as default browser.
Postby Alice » Tue 01 Feb, 2005 3:44 pm
joc wrote:Thaks you Alice for your quick reply. I tried exactly what you mentioned about the resetting the "mail.default_sendlater_uri", then changing it to point to my new server name. I still got the exact same message.
Sorry, don't know what may be the problem unless it's some mail-screening antivirus, firewall or spam-killer program that acts in a way similar to the "message copy" bug.... see
https://bugzilla.mozilla.org/show_bug.cgi?id=221386
"Mozilla doesnt save the " Copies and Folders " page in the " Mail and Newsgroups Account Settings"
Do you have any such program set to scan your outgoing mail?
joc wrote: I wouldn't mind upgrading to 7.2 if it won't cause further problems. I seem to remember attempting to go to 7.2 months and having horrendous problems with the being able to download email afterwards (might have bene a beta version, though). Do you know of any issues with migrating from 7.1 to 7.2? Also, is there any reason why I shouldn't go to thunderbird?
No reason why you shouldn't be able to UNinstall Netscape 7.1, then install Netscape 7.2 and have it pick up your old mail, although SOME people do report problems accessing the old Netscape 7.1 profile data, for whatever reason.
Installing Thunderbird FIRST, with Netscape 7.1 still installed, is a great idea..... it will migrate your old mail from Netscape 7.1, so that you'll have a COPY of all the messages in Thunderbird.
See:
http://mozillanews.org/?article_date=20 ... 7+16-19-25
Mozilla Thunderbird 1.0 Getting Started Guide
[tt]Migrating on First Launch
If you have never installed Thunderbird before, you will see an import wizard when you open Thunderbird the first time.[/tt]
[tt]The wizard gives you the option to import from Mozilla or Netscape, Microsoft Outlook, or Microsoft Outlook Express. Select what you want to import and press Next to automatically import your mail, account settings, and address books. For other mail clients or other mail Mozilla/Netscape profiles, you can import manually later.
Note: Thunderbird does not give you the option to import mail and account settings from Mozilla and Netscape after this. If you need to import from multiple clients, choose to import from Mozilla / Netscape first. <snip>[/tt]
Postby captjlddavis » Tue 01 Feb, 2005 4:27 pm
The thread trend seems to have shifted from "unsent"folder to migrating mail.
To return to the original subject:
There can be only one active "unsent" folder per mail profile.
There can be several mail accounts with in the mail profile.
You can change the folder from "Local Folder" to another account as discribed above and it does work.
First you need to understand the difference between "Draft"and "Unsent" .
Consider "Draft" as a work in progress and "Unsent" as a completed work waiting to be sent.
Please see my reply:
Here
Although it pertains to "return receipt" it clarifies how things work with regards to Draft and Unsent mail.
Logically it is best to leave the "unsent" messages in the Local Folders - But that is just MHO - it does not make sense to have unsent messages from one mail account in another mail account folder.
regards:captjlddavis
Edited for spelling and such.....
captjlddavis
gold member
gold member
Postby joc » Tue 01 Feb, 2005 9:34 pm
ok..here is the latest. I have installed NS7.2 It is working (so far). I have my folders intact, mail contacts intact, the whole bit. But of course, the original problem remains. I am not able to switch my "unsent" folder from local to another account. I am still getting the same error message telling me that a copy has failed. This is quite frustrating. These errors give you no usable clues as to what the problem may be or how to resolve them. On a better note, I was having problems "POP"ing my Gmail email. Going to 7.2 seems to have solved that problem. Still, thanks for the help folks and if anyone has any other ideas, I'm waiting in despair :cry:
joc
Postby Alice » Wed 02 Feb, 2005 6:59 am
Congratulations on a successful upgrade to Netscape 7.2... Sorry the "send later" function still isn't working when you modify the Unsent Messages folder location.
Can you use "send later" without errors if the mail.default_sendlater_uri preference is reset to the default Local Folders location?
If the problem only occurs when you attempt to switch the active Unsent Messages folder to a specific mail account, I would reset the preference back to the default "Local Folders". Next, I would try removing and then recreating the problem mail account, using the "Remove Account" and "Add Account" buttons in the main "Mail&Newsgroup Account Settings" window.
This will add new entries in the prefs.js file and create a new, empty "pop-server.midsouth.rr.com" folder in your ...\Mozilla\Profiles\"profilename"\xxxxxxxx.SLT\MAIL folder, named something like, pop-server.midsouth.-1.com , in addition to the current "pop-server.midsouth.rr.com" folder that now holds the Inbox, Sent, and other mailbox files... So, if you have current mail, you could EITHER copy the current mailbox contents within Netscape to Local Folders before removing and recreating the mail account ....
OR, after recreating the mail account you can simply use the Mail&Newsgroup Account Settings, Server Settings, "Browse" button to the right of the Local Directory field, to point back to the original MAIL\ pop-server.midsouth.rr.com folder ..... details here:
http://home.att.net/~cherokee67/ns7lostprofwinxp.html
If you prefer, create a new profile and then migrate your old MAIL and other profile data to the new profile if the "send later" feature works in a new profile, using one of these pages as a guide for migrating specific data like Mail, address book, passwords, bookmarks, etc:
http://ilias.ca/netscape/profilefaq/#transferring (under "Selectively Transferring certain data")
http://home.att.net/~cherokee67/NS7newprofile.html
http://users.adelphia.net/~irwingreenwa ... ml#copying
Then modify the mail.default_sendlater_uri preference again, once the new account or new profile is set up.
Hopefully, someone else might come up with an easier fix.... but, If I were you, I would simply use the default "Local Folders" Unsent Messages folder if it's working OK.
Postby Amrad » Thu 03 Feb, 2005 4:33 am
Ramona wrote:Hi ten13,
I agree with you, Ramona, The Drafts and Unsent Messages folders are not the same.
Depending on the settings in Edit/Preferences/Mail & Newsgroups/Offline & Disk Space/When going online:
This gives three options:
1. Ask me if I want to send my unsent messages
2. Automatically send my unsent messages
3. Do not send my unsent messages.
These preferences apply only to the Unsent Messages folder, but not to the Drafts folder.
Any messages stored in Drafts will only be sent if you click on the Send button, messages stored in the Unsent Messages folder, on the other hand, will be sent (or not) according to the above preference settings.
Regards,
Dave.
UserAgent: Mozilla/5.0 (Windows; U; Win 9x 4.90; en-US; rv:1.7.5) Gecko/20041217
Amrad
