Start-up Problem - Can't Log In
Postby khimkhoykhi » Mon 26 Dec, 2005 1:09 am
Hi!
I did some search but can't seem to find a problem like mine. Hope somebody can help me!!!
My niece played with my iBook two nights ago (when I went out of the room to get something) and when I came back I noticed that the open applications started to fail and quit. So I shut my iBook down and then restarted it. It started out fine until the log in page. I was asked to input my password (which is normal) and then clicked log-in. It said logging in and then I saw a blue screen which stayed that way, instead of loading my start up applications and desktop. All I can see is an empty blue screen. I then tried to restart/shut it down again but same thing happened. I can see the Mac OS X initializing then asking me to log-in then the blue screen.
I then tried some do-it yourself troubleshooting by logging in on a safe mode. Same thing happened, when I input my password (on a safe boot mode), all I can see is an empty blue screen.
I also tried to start-up in single-user mode and check fsck by typing /sbin/fsck -fy on the command prompt but it said my volume HD is OK. I am on vacation and I haven't brought my Disk Utility disc with me so I'm using fsck.
Another thing I tried is to reset PMU by removing the battery and holding down the Power key for 5 seconds and then turning it on again. Still same problem, desktop won't show after I log-in.
I am really confused what went wrong.I've never experienced any problem with my iBook since I bought it last May, 2005. There is no Apple Center near where I am right now so I can't have it checked up. But I badly need my iBook to do some work.
Here are some specs of my iBook G4 12", 768MB RAM,
30GB HDD, OSX Tiger bought last May 2005.
I really, really would appreciate any help!!! Thanks so much and Happy Holidays!
Jo-Ann
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows 98)
khimkhoykhi
Postby Antony » Mon 26 Dec, 2005 1:25 am
Jo-ann,
Is the blue screen you see the default blue background colour (before loading the background wallpaper?) And can you see menubar or Dock at all?
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/416.12 (KHTML, like Gecko) Safari/416.13
Postby Antony » Mon 26 Dec, 2005 8:53 am
Jo-ann,
Have you tried logging into Single-User mode (NOT safe mode)?
Postby khimkhoykhi » Wed 28 Dec, 2005 6:47 am
Yes, the blue screen I see is the default blue background before loading the wallpaper and I can't see the menubar or dock at all. I only see an empty blue default blue background...=(
Antony wrote:Jo-ann,
khimkhoykhi
Postby khimkhoykhi » Wed 28 Dec, 2005 7:00 am
Yes I did try logging in in a single user mode but still the same thing happened, I can only see the blue default screen . I also tried the fsck check (which is like Disk Utility I think) and this can only be done when you are logged in as single user. When I did the fsck, it checked 5 phases of my HD and then the result said my HD is okay. But when I restarted my iBook, I can only see the default blue screen still (after I input my password for log-in). :?
khimkhoykhi
Postby Antony » Thu 29 Dec, 2005 1:47 am
When you are in single-user mode,
Try deleting following .plists
[tt]com.apple.systempreferences.plist[/tt]
[tt]com.apple.systemuiserver.plist[/tt]
located under [tt]/User/[yourUserName]/Library/Preferences[/tt].
