Firescape - My own customized version of Firefox 1.5
Moderator: Don_HH2K
Postby Pu7o » Mon 02 Jan, 2006 6:11 pm
OK, here's the official en-US language pack for Firescape 0.1b3 (Windows only). If anyone wants a language pack for another language, post here the language and operating system and I might try to make one.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.2; en-US; rv:1.8) Gecko/20060101 Firefox/1.5 Firescape/0.1b3 wml/1.3
Postby beanboy89 » Mon 02 Jan, 2006 6:57 pm
Pu7o wrote:OK, here's the official en-US language pack for Firescape 0.1b3 (Windows only). If anyone wants a language pack for another language, post here the language and operating system and I might try to make one.
Thanks. I downloaded it, but how do I install it?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-GB; rv:1.8) Gecko/20060101 Firefox/1.5 Firescape/0.1b3 wml/1.3
Postby Pu7o » Mon 02 Jan, 2006 7:17 pm
It's a XPI, just drop it into the extensions window and it will do its thing.
Also...
I've been playing with the language XPIs, and created a script to convert a language pack to firescape automatically. I also created another which takes all available firefox language packs and passes them to the first script. So soon, I should have all language packs, and will upload them all.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.2; es-ES; rv:1.8) Gecko/20060101 Firefox/1.5 Firescape/0.1b3 wml/1.3
Postby beanboy89 » Mon 02 Jan, 2006 7:25 pm
Pu7o wrote:It's a XPI, just drop it into the extensions window and it will do its thing.
Thanks.
Also, I went to test the uninstaller and I got this error:
I think it is related to me tring to install that Firefox language pack, or maybe whan I tried to import the [tt]chrome\en-US\[/tt] folder from beta 2. Regardless, I'm not sure why it's happening, but it's preventing me from uninstalling the program. I'm not sure if it matters, but I didn't install Firescape in the default location.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8) Gecko/20060101 Firefox/1.5 Firescape/0.1b3 wml/1.3
Postby Pu7o » Mon 02 Jan, 2006 7:41 pm
I didn't test the uninstaller either. I'll have to fix that. In the meantime, to uninstall it, just remove the whole dir.
Language Packs for Firescape
Postby Pu7o » Mon 02 Jan, 2006 7:45 pm
Here are the links to ALL the language packs for Firescape v0.1 beta 3. It was quoted to save space. Also, en-US and en-GB are not included (I'll do a Mac en-GB and Linux en-US later).
Language Packs:
ar:
ca:
cs:
da:
de:
el:
es-AR:
es-ES:
eu:
fi:
fr:
ga-IE:
he:
hu:
it:
ja:
ko:
mk:
nb-NO:
nl:
pl:
pt-BR:
ro:
ru:
sk:
sl:
sv-SE:
tr:
zh-CN:
zh-TW:
Postby beanboy89 » Mon 02 Jan, 2006 11:16 pm
I just noticed that the Firescape installer seems to put an entry under Internet in Windows XP and 2003's Start Menu options. Right click on the Start Button > Properties > Choose Start Menu radio button > click Customize > under the Show on Start menu option for Internet, Mozilla Firefox appeared in the list after installing Firescape. There is a seperate Firescape entry. If I choose the "Mozilla Firefox" option a broken shortcut is added to the Start Menu.
Edit: I found the entry in the Registry at [tt]HKEY_LOCAL_MACHINE\SOFTWARE\Clients\StartMenuInternet[/tt]. It seems the "Mozilla Firefox" entry is tied to the Firescape install directory.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8) Gecko/20051205 Donzilla/1.0 (WML/1.3)
Postby Don_HH2K » Tue 03 Jan, 2006 9:17 am
I believe that specific problem is tied to one of two places: the executable, or a file in en-US.jar called brand.properties. Make sure you set "Mozilla Firefox" to say "Firescape" in brand.properties. Furthermore, you may need to modify some resources in the executable using Resource Hacker or a similar PE-editing tool. If what holds true for Firefox is true for Seamonkey, the fields you need to edit are located in what should be the only string table that you can view.
STRINGTABLE
LANGUAGE LANG_ENGLISH, SUBLANG_ENGLISH_US
102,    "Mozilla Firefox"
103,    "Mozilla Firefox"
to this
STRINGTABLE
102,    "Firescape"
103,    "Firescape"
Postby DJGM » Tue 03 Jan, 2006 12:31 pm
Re: en-GB vs en-US . . .
The only differences between en-GB and en-US, is the use of British English (aka proper English
or The Queen's English) spellings of certain words, rather than the American English spellings.
Functionality wise, they're pretty much the same as each other . . .
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.2; en-US; rv:1.7.12) Gecko/20050915
Postby Pu7o » Wed 04 Jan, 2006 7:47 am
Since Mac OS X users were pretty much left out on the latest beta, beta 3, the next version will have a major Mac OS X improvement:
(Click thumbnail for full screenshot, 1024x768)
Full native aqua widgets on HTML pages! Something that, so far, was unseen on any version of Firefox! Stay tuned for more! ;)
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X Mach-O; en-US; rv:1.8) Gecko/20060104 Firefox/1.5 Firescape/0.1RC1-dev wml/1.3
Postby Antony » Wed 04 Jan, 2006 9:27 am
Pu7o wrote:Since Mac OS X users were pretty much left out on the latest beta, beta 3, the next version will have a major Mac OS X improvement:
What should I be looking at from the screenshot?
And what are the "aqua widgets"?
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/416.12 (KHTML, like Gecko) Safari/416.13
Postby Pu7o » Wed 04 Jan, 2006 9:52 am
The controls in the screenshot, inside the webpage, are Aqua controls, not the "Windows 9x-like" controls that regular Firefox has.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.2; pt-BR; rv:1.8) Gecko/20060101 Firefox/1.5 Firescape/0.1b3 wml/1.3
Postby Pu7o » Wed 04 Jan, 2006 10:02 am
In comparison, here is a screenshot of Firefox as it looks like by default.
Postby Pu7o » Sun 15 Jan, 2006 9:09 pm
Well, Firescape 0.1 Release Candidate 1 is ready for Mac OS X. I will post the link once the Windows version is ready too.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X Mach-O; en-US; rv:1.8.0.1) Gecko/20060115 Firefox/1.5.0.1 Firescape/0.1 wml/1.3
Postby Antony » Sun 15 Jan, 2006 9:15 pm
I installed Firescape 0.1 RC1.
After installing, I double clicked Firescape.app (under /Applications/Firescape ), it won't launch.
Return to SD701 DevZone
