Donzilla 1.0 Released
Postby beanboy89 » Tue 03 Jan, 2006 8:24 pm
Don_HH2K wrote:I just applied this to my userChrome.css file (after removing the ending "p", which would screw it up)
My falut. The "p" was a typo when putting the ending "[/code]" tag in. Fixed in original post.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8) Gecko/20051205 Donzilla/1.0 (WML/1.3)
Postby Antony » Tue 03 Jan, 2006 9:28 pm
Don,
can Donzilla apply any language packs?
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/416.12 (KHTML, like Gecko) Safari/416.13
Postby Don_HH2K » Tue 03 Jan, 2006 9:37 pm
Antony wrote:Don,
In short... it can, but as a result it'll start calling itself "Seamonkey" again, and about: will break since it uses a DZ-specific entity not defined in other language packs.
I might be interested to see what happens if I write a "Mozilla to Donzilla Language Pack Converter". While it doesn't happen, you can tell me what language you want (provided there's a Seamonkey equivalent) and I can convert it for you.
Re: update
Postby Fulvio » Tue 03 Jan, 2006 9:43 pm
Don_HH2K wrote:
Fulvio wrote:A brand new profile works ok, as far as the browser is concerned, but I cannot seem to get any mail set up. The folders are in place, but no account shows up. Only Local folders are there. This is the most bizarre event ever.
But Sidebar and message pane are ok. I will have to see if some crazy setting is off, but what and why?
I bet I know exactly what that is. There's a feature new to Seamonkey that lets you put all your mail into one inbox in Local Folders. When you go to set up an account, you need to uncheck the box that says "Use Global Inbox". All seems to work if I uncheck that box.
The feature has been in Thunderbird, but I think that I got caught into something. But, there was nothing into Local folders. I found later that, since I keep mail on server for 11 days, or until mail is sent to trash, there was nothing there. I have no idea how this Global Inbox works, but it is insane to use it with 11 active accounts. The entire thing was very perplexing because I copied my old (and renamed) Inbox to the same account, and I could not see the renamed folder. Where is it?
Anyway, I removed the account, and that's when I noticed global Inbox prompt (it should never be default). And, the account showed up ok. But, Local folders must have, still been default, until I added another account, and selected default. So, your diagnosis was correct. So, Donzilla is working ok. It is running at over 56 MB memory usage.
Now, I will have to cut down the number of Search engines.
Postby Al » Sat 21 Jan, 2006 2:46 pm
Off topic: I'm trying to download Donzilla but for some reason, Hardwarehacks 2000 is down.
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.8) Gecko/20051111 Firefox/1.5
Al
Postby Don_HH2K » Sat 21 Jan, 2006 2:50 pm
Al wrote:Off topic: I'm trying to download Donzilla but for some reason, Hardwarehacks 2000 is down.
I know. HH2K has been down for about a day due to server problems.
Edit -- HH2K isn't back up yet, but downloads have been restored to the server and are now available.
Postby Antony » Thu 16 Mar, 2006 9:23 am
May I know where the default preference and profile path for Donzilla?
Thanks.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X Mach-O; en-US; rv:1.8) Gecko/20051221 Donzilla/1.0 (WML/1.3)
Postby Pu7o » Thu 16 Mar, 2006 12:37 pm
That depends on the platform. Here are the lists of the profile locations for Donzilla:
    Windows 2000 and XP:
      :arrow: <DRIVE>:\Documents and Settings\<USERNAME>\Application Data\Mozilla\Profiles
    Windows NT 4, 3.51:
      :arrow: <DRIVE>:\WINNT\Profiles\<USERNAME>\Application Data\Mozilla\Profiles
    Windows 95,98,ME:
      :arrow: <DRIVE>:\Windows\Application Data\Mozilla\Profiles
    Linux:
      :arrow: ~/.mozilla/profiles
    Antony's beloved Mac OS X:
      :arrow: ~/Library/Mozilla/Profiles
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en) AppleWebKit/420+ Trunk/20060227 (KHTML, like Gecko) Shiira/1.2.2 Safari/125
Postby beanboy89 » Thu 16 Mar, 2006 3:53 pm
Pu7o wrote:That depends on the platform. Here are the lists of the profile locations for Donzilla:
Windows 95,98,ME:
    :arrow: I don't know.
Windows 9x should be [tt]<drive>:\Windows\Application Data\Mozilla\Profiles\[/tt].
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060130 SeaMonkey/1.0
Postby Pu7o » Thu 16 Mar, 2006 6:01 pm
Windows 95,98,ME:
Thanks, added.
Postby Don_HH2K » Thu 16 Mar, 2006 6:22 pm
It should be noted that on 2000 and higher you can access your Application Data folder from %APPDATA%, so technically it can be made easier by using [tt]%APPDATA%\Mozilla\Profiles\[/tt]
Postby Antony » Thu 16 Mar, 2006 6:28 pm
Pu7o wrote:Antony's beloved Mac OS X:
[/list]
So the profile may be shared with other Mozilla applications?
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/417.9 (KHTML, like Gecko) Safari/417.9.2
Postby Don_HH2K » Thu 16 Mar, 2006 7:00 pm
A Donzilla profile is essentially exactly as the same as a Mozilla profile, save for the defaults being different if the profile was created with Donzilla (which wouldn't cause any problems). For the most part, Donzilla and Mozilla/Netscape profiles are interoperable, though I recommend that users have a separate profile anyway.
Postby Antony » Thu 16 Mar, 2006 7:32 pm
then, how can I tell which profile is for Donzilla?
Postby Don_HH2K » Thu 16 Mar, 2006 7:57 pm
For the most part, just name them differently.
By default, there will only be one profile in there.
