Thunderbird 1.5 Official Release Now Available
You are here:  SillyDog701 > Message Centre > Firefox, SeaMonkey and Netscape > [sdt=10622]
SillyDog701 Forums
Author Message
11 Jan, 2006 7:33 pm Thunderbird 1.5 Official Release Now Available [sdp=68665]
Download Thunderbird 1.5 Final, from these links:
Thunderbird 1.5 Web Site
FTP Site
Release Notes
What's New:
Here's what's new in Thunderbird 1.5:
* Automated update to streamline product upgrades. Notification of an update is more prominent, and updates to Thunderbird may now be half a megabyte or smaller. Updating extensions has also improved.
* Sort address autocomplete results by how often you send e-mail to each recipient.
* Spell check as you type.
* Saved Search Folders can now search across multiple accounts.
* Built in phishing detector to help protect users against email scams.
* Podcasting and other RSS Improvements.
* Deleting attachments from messages.
* Integration with server side spam filtering.
* Reply and forward actions for message filters.
* Kerberos Authentication.
* Auto save as draft for mail composition.
* Message aging.
* Filters for Global Inbox.
* Improvements to product usability including redesigned options interface, and SMTP server management.
* Many security enhancements.
The Rumbling Edge has more detailed lists of new features and notable bug fixes.
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7.12) Gecko/20050915 Firefox/1.0.7 (ax)
Back to top profile
Site Admin
11 Jan, 2006 8:56 pm [sdp=68671]
Thanks Ramona,
is “version 1.5 (20051201)” the official 1.5?
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/416.12 (KHTML, like Gecko) Safari/416.13
Back to top profile website
11 Jan, 2006 9:04 pm [sdp=68672]
Antony,
Yes, that is the official Release, and Mozilla finally announced the release on mozilla.org:
Official Release Post on mozilla.org:
Wednesday January 11th, 2006
Thunderbird 1.5 Released
Scott MacGregor writes: "The final release of Mozilla Thunderbird 1.5 is now available for download from getthunderbird.com. Users of RC1 should see the update soon. If you are using RC2, then you already have 1.5 final."
"Thunderbird 1.5 introduces several new features including a software update system, spell check as you type, built in phishing detector, auto save as draft, and support for deleting attachments from email messages. Message filtering has also been improved with new filter actions for replying and forwarding. Saved search folders can now search folders across multiple accounts."
Read more...
Back to top profile
11 Jan, 2006 9:15 pm [sdp=68673]
Oh, well. I uninstalled 1.5rc2, and installed 1.5. Actually, it was a good idea, because I had created a separate folder for 1.5rc2. Now, I have a different one called Thunderbird1.5. And, TB1.5 works fine as the mail client of choice in Kmeleon, so I can compare 1.5 and 1.0.7, as if I needed it.
Both are good.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.12) Gecko/20050914 K-Meleon/0.9
"I've got a very poor sense of direction. I keep forgetting which way is forwards."
WinXP, SP3, 512 MB, 3.0.15 regular, 3.5.5 regular and portable , TB2.0.0.23, Flock2.5.2, IE8.0, SM2.0, Google Chrome2.0.x, Safari4.0.4, Zone Alarm; AVG9.0, JRE1.6_17
Back to top profile
Site Admin
11 Jan, 2006 9:24 pm [sdp=68675]
Ramona,
Thanks for clarifying. I was a bit confused with the built date.
Sirdar
11 Jan, 2006 11:18 pm [sdp=68680]
As a warning...I read on MozillaZine that people are having trouble after installation due to the fact that they installed over their previous version. But if you read the installation instructions it says:
"Windows - Double click the Thunderbird Setup 1.5.exe installer to start the install."
Way farther down the release notes it says:
"All Systems - Prior to installing Thunderbird 1.5, please ensure that the directory you've chosen to install into is clean and doesn't contain any previous Thunderbird installations."
So make sure you don't install it over a previous version.
But why won't it install properly over a previous installation like you could when installing Firefox?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8) Gecko/20051111 Firefox/1.5
Site Admin
12 Jan, 2006 12:13 am [sdp=68682]
Thanks Sirdar,
I installed it over the previous Thunderbird I used (1.0x), and I did not experience any problems.
I am a Mac user, BTW.
captjlddavis
gold member
12 Jan, 2006 2:13 am [sdp=68697]
Win xp home
Previous INSTALLED
TB 1.5rc in non standard location = E:\program files\TB_1.5rc
Add/Remove = Mozilla Thunderbird 1.5
Registry reference = C:\WINDOWS\UninstallThunderbird.exe /ua "1.5 (en-US)"
INSTALLED TB 1.5 Final to non standard location = E:\program files\TB_1.5_final\
New install (TB 1.5 Final) does not effect previous (TB 1.5rc)
HOWEVER the Add/Remove entry refers to and uninstalls the LAST 1.5 version that was installed. NO way to remove via Add/Remove the previous 1.5rc version.
I had to remove the Directory and Clean the registry to get rid of traces of the previous 1.5rc installation.
Don't know if this means anything, but just wanted to point it out to anyone that installs 1.5 final with 1.5rc installed.
regards:captjlddavis
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8) Gecko/20051219 SeaMonkey/1.0b
Back to top profile
RootsMan
16 Jan, 2006 8:58 am [sdp=68885]
Greetings,
On a Windows XP SP2 system, I installed Thunderbird 1.5 over a v1.0.7 with no ill effects. The user's profile was previously moved to a data directory on a 2nd hard disc drive. TB 1.5 picked it up without a hitch.
I hadn’t seen the recommendation to not install in the same directory as a previous version until later. They probably should place that message in a more prominent location.
RootsMan
16 Jan, 2006 10:57 am [sdp=68890]
Like Antony, I also installed over a previous version (1.0.7) with no ill-effects. And like others... I also did NOT see the warning until after the fact. Brilliant placement.
It's later than you think.
Firefox 3.5.3, IE 8
Back to top profile
18 Jan, 2006 9:08 am [sdp=68983]
Just a small note:
The title says "Thunderbird 1.5 Offical...", it should be Official.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X Mach-O; en-US; rv:1.8) Gecko/20060118 Firefox/1.5.0.1 Firescape/0.1 wml/1.3
Display posts from previous:
Reply to topic    Forum Index > Firefox, SeaMonkey and Netscape All times are CST (GMT -6)
page 1 of 1
To add your questions, comments, and for more features and more, please join SillyDog701 Message Centre. It's free! This is SillyDog 701 Message Centre (SD701 Forums).
James Blunt Your favourite music, radio, music videos, TV shows, movies and more...
Download on iTunes
*Search | FAQ | Rules and Policies | MozInfo701 - Mozilla Information Centre | SD701 Open Directory | Message Board Map | download Netscape
