A question about the DJGM.co.uk Toolbar . . .
Moderator: Don_HH2K
Postby DJGM » Thu 26 Jan, 2006 7:33 pm
Several weeks ago, I released the DJGM.co.uk Toolbar v1.0, but for Firefox only. Now that I've
upgraded/migrated from Mozilla App-Suite 1.7.12, to Seamonkey 1.0 beta as my primary web
browser, I'd like to make the toolbar available to install as a SeaMonkey extension.
Any idea how I should go about doing this? Would anyone be willing to help me out with this?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.2; en-US; rv:1.8) Gecko/20051219 SeaMonkey/1.0b
Postby Don_HH2K » Thu 26 Jan, 2006 8:00 pm
I'd be willing to help.
As for going about porting it, there may not be a lot of work that needs to be done. First, you should see how much of it works in Seamonkey; try placing the .jarfile for the Toolbar in seamonkey/chrome, then manually register the JAR to Seamonkey in installed-chrome.txt using the same syntax that the preexisting entries follow, basing it on the JAR file's directory structure. So, let's say you had [tt]toolbar.jar!/content/chrome.rdf[/tt] and [tt]toolbar.jar!/locale/en-GB/locale/chrome.rdf[/tt], you'd add those into installed-chrome.txt like this:
content,install,url,jar:resource:/chrome/toolbar.jar!/content/
locale,install,url,jar:resource:/chrome/toolbar.jar!/locale/en-GB/locale/
Then delete [tt]chrome.rdf[/tt], [tt]overlays.rdf[/tt], and [tt]stylesheets.rdf[/tt] from seamonkey/chrome (they will be rebuilt on launch) and fire up Seamonkey.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8) Gecko/20051205 Donzilla/1.0 (WML/1.3)
Postby DJGM » Thu 26 Jan, 2006 8:40 pm
I was wondering ... since Mozilla App-Suite and SeaMonkey both use install.js script files for the
installation of extensions/themes would it work if I added an install.js file to the existing XPI?
If so, what would need to be written in the install.js file, or could I edit an existing install.js file
from a similar extension, such as the Netscape Toolbar that was bundled with Netscape 7.2.
Postby Don_HH2K » Fri 27 Jan, 2006 11:37 am
You may want to take a look at XPIMaker, which can be used to create XPI files. I've never used it before, so I don't know how much of the XPI-building process it performs for you.
Mozilla also has a guide to making install.js files compatible with Mozilla Suite XPIs available on the XPInstaller project homepage.
Return to SD701 DevZone
Registered users: Google [Bot], MSN [Bot]
