NS8.1 no required permissions to perform action?
Postby Antony » Mon 06 Feb, 2006 7:48 am
Does anyone know what caused the “You don't have the required permissions to perform this actionâ€
Postby Fulvio » Mon 06 Feb, 2006 11:04 am
Antony,
I never had the problem, but from the link, I see reports of possible association with the Anti Spyware. That "feature" is awful. I had to uninstall NS8.1, once, to make it work at all, and, after I did full scans, it came up with "problems" which were not seen by any other anti spyware.
It is possible that the NS8.1 is better than all the others, but the simple fact that it throws some names with no description, and location is very poor. I left a Feedback, saying that they should work on the antiSpyware, or make it an optional installation. Since I have not seen problems if I don't use AS, don't use it. NS8.1 is usable, if you ignore AS.
I have the Microsoft AS beta, Adware, Spybot S & D and Spyware Blaster. All of them are very informative, and have done well.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.12) Gecko/20050915 Firefox/1.0.7 (ax)
Re: NS8.1 no required permissions to perform action?
Postby macallan1824 » Tue 07 Feb, 2006 6:26 am
[quote="Antony"]Does anyone know what caused the “You don't have the required permissions to perform this actionâ€
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7.5) Gecko/20060111 Netscape/8.1
macallan1824
Postby Antony » Tue 07 Feb, 2006 8:54 pm
Thanks macallan1824 for the information.
