Deleting Email Storage Folders Netscape 7.02
Postby lindenhills » Wed 22 Mar, 2006 1:03 pm
Hi dear 'Scapers - I routinely set up email storage folders for client projects; usually, deleting these folders is no problem. Now I have a folder that doesn't want to leave: no matter how I try to delete it--rightclick, drag-n-drop--nothing works. Does anyone know what is happening here? Or how to delete this stubborn folder? :oops:
Thanks!!!
lindenhills
Postby Fulvio » Wed 22 Mar, 2006 1:10 pm
Are you deleting from Windows Explorer?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.13) Gecko/20060319 Firefox/1.0.8
Postby lindenhills » Wed 22 Mar, 2006 1:15 pm
No, Netscape 7.02... =^..^=
lindenhills
Postby Fulvio » Wed 22 Mar, 2006 1:40 pm
Then, try deleting from Windows Explorer, with 7.0.2 closed.
I notice that you are using 7.2. Did you mean 7.0.2?
And, do you know where the profile is located, and the folders are hidden in WinXP? The location is:C:\Documents and Settings\user_name\Application Data\Mozilla\Profiles\xxxxx.slt\Mail\mail account
To see hidden files:
1. On the Tools menu in Windows Explorer, click Folder Options
2. Click the View tab
3. Under Hidden files and folders, click Show hidden files and folders
4. Disable "Hide File Extensions for Known Files."
5. Click OK.
Postby lindenhills » Wed 22 Mar, 2006 3:31 pm
It worked...of course. You are geniuses, bless you. It was driving me crazy. Thank you!!!
8-)
lindenhills
Postby Fulvio » Wed 22 Mar, 2006 3:34 pm
I did my share of hitting my head against the wall.
I am glad that i prevented further injuries!
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.13) Gecko/20041220 K-Ninja/Samurai
