Mighty mouse won't scroll down
Postby Pu7o » Mon 27 Mar, 2006 1:46 pm
Somehow, my mighty mouse no longer scrolls down (with the scrollball), in any application (I tried iTunes and Firefox). Scrolling up works fine, it works sideways as well. Does anyone have any idea how to fix this?
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en-US; rv:1.8) Gecko/20060319 Firefox/2.0a1
Postby Antony » Mon 27 Mar, 2006 4:13 pm
clean it.
use a piece of paper, slide into it, and clean out the dust.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/417.9 (KHTML, like Gecko) Safari/417.9.2
Postby Pu7o » Mon 27 Mar, 2006 4:19 pm
Thanks, worked fine :)
Postby Antony » Mon 27 Mar, 2006 5:35 pm
remember to keep your hands and mouse clean when using it.
Postby Antony » Sun 09 Apr, 2006 9:51 pm
How to clean your Mighty Mouse (Apple Knowledge Base)
Apple wrote: Although your Mighty Mouse never needs to be fed or watered, you may occasionally find that you need to clean it.
If your Mighty Mouse is covered in fingerprints or its surface has become soiled, it can be gently wiped with a clean lint-free cloth. If necessary, moisten the cloth using only water, making sure not to oversaturate it. Be aware that the mouse contains electronic components that may be damaged if water drips from the cloth into the mouse via the seam around the scroll ball or around its underside.
The same procedure can be used to clean the scroll ball on your Mighty Mouse if it has become discolored or dirty. Use a clean lint-free cloth lightly moistened with water. Wipe the ball and the surrounding area, making sure to rotate the ball itself to ensure complete coverage. If the scrolling feels rough, hold the mouse upside-down and roll the ball vigorously while cleaning it to help dislodge any particles that may have collected on the internal hardware.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/418 (KHTML, like Gecko) Safari/417.9.2
Mighty Mouse won't scroll down
Postby Swistone » Mon 16 Nov, 2009 7:02 pm
I was an Apple tech for a year and the best repair I have found it to take a thick piece of paper on a table and roll the mouse button back and forth, up and down and side to side, to dislodge the gunk that collects after time. You should see a little black splotch of dirt stick to the paper after a few seconds of vigorous rubbing. It's just the natural skin oil and sweat and dust that collects after time.
This will do the trick every time, I guarantee.
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.5) Gecko/20091102 Firefox/3.5.5
Swistone
Postby sussane » Sun 10 Jan, 2010 10:56 pm
I am also having problem with Mighty Mouse, i don't know why i bought this one ... so costly and problematic....
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.7) Gecko/20091221 Firefox/3.5.7 GTB6 (.NET CLR 2.0.50727)
sussane
Re: Mighty mouse won't scroll down
Postby peachgirl » Tue 18 Jan, 2011 9:02 am
Thank you, thank you, thank you! These tips worked wonders! I was frustrated beyond words, thinking my mighty mouse had wimped out on me :) Especially the turn upside down and roll ball vigorously. Thank you!
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10_6_6; en-US) AppleWebKit/534.10 (KHTML, like Gecko) Chrome/8.0.552.237 Safari/534.10
peachgirl
Postby Joolz » Tue 29 Mar, 2011 12:18 am
You legends! Thank you for all that advice.
Now.... can anyone help me put my DVDs onto ITunes?
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.2.16) Gecko/20110319 Firefox/3.6.16
Joolz
Postby Antony » Tue 29 Mar, 2011 6:09 am
Joolz wrote:Now.... can anyone help me put my DVDs onto ITunes?
Well, in short, you have to rip the contents off DVDs, then encode to video format that iTunes understand (H.264 is preferred).
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.2.16) Gecko/20110319 AlexaToolbar/alxf-2.11 Firefox/3.6.16
