How Does Your Opera Look
Opera web browser and M2 mail client from Opera Software. (for Windows, Macintosh and Linux.)
Moderators: Edward, Mandrake
Postby blinkybill » Mon 27 Mar, 2006 7:37 pm
Here is my IE7fied Opera 9
http://img69.imageshack.us/img69/7538/operaie70kx.jpg
cheers
blinky
UserAgent: Opera/9.00 (Windows NT 5.1; U; en)
blinkybill
Re: How Does Your Opera Look
Postby DJGM » Tue 20 Jun, 2006 1:35 pm
blinkybill wrote:Here is my IE7fied Opera 9
cheers
blinky
But that screengrab is IE7 . . . There's no way (yet) to make Opera look exactly like IE7. And if even there was,
why on God's green and pleasant Earth would you want the GUI of Opera to emulate the awful GUI of IE7?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.4) Gecko/20060516 SeaMonkey/1.0.2
Postby Pu7o » Tue 20 Jun, 2006 2:32 pm
Here's how my Opera looks like (1440x900).
UserAgent: Opera/9.00 (Macintosh; Intel Mac OS X; U; en)
IE7 Opera
Postby blinkybill » Tue 20 Jun, 2006 6:42 pm
Hi DJGM,
I am sorry you are wrong on your assumption that it is IE 7 and not Opera
and also that it can't be done as it has and not only by me but other people
on the Opera forums.
For me the look of IE 7 is way better than Opera 9 or Firefox so thats
why I made it. But for me I don't care what people choose to use as
long as they enjoy and it suits them.
I would be happy to send you the skin and toolbar.ini file to you
if you want it or would like to see it is actually been done.
By the way here is my latest update pic...with work I did on the tabs.
http://img144.imageshack.us/img144/8137/ie72db.jpg
cheers
blinky
UserAgent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; SV1)
blinkybill
IE7 Beta 3
Postby blinkybill » Sat 01 Jul, 2006 9:02 pm
Been doing more updating on my Opera 9 skin to
make it look like the latest Internet Explorer 7 Beta 3
Here is a pic.
http://img72.imageshack.us/img72/7469/ie7beta39lk.png
cheers
blinky :)
UserAgent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1)
blinkybill
Re: IE7 Beta 3
Postby DJGM » Sat 01 Jul, 2006 9:27 pm
blinkybill wrote:Hi,
Here is a pic.
cheers
blinky :)
Again, that looks to be a screengrab of IE7, not a customised Opera. Unless of course, you can prove to us otherwise.
Type [tt]opera:about[/tt] into your customised Opera, made to look exactly like IE7, and please post a screengrab of it here.
If Opera 9 for Windows can be made into a clone of IE7, then I should be able to do the same on Opera 9 for Mac OS X.
UserAgent: Opera/9.00 (Macintosh; PPC Mac OS X; U; en)
Re: IE7 Beta 3
Postby beanboy89 » Sat 01 Jul, 2006 11:30 pm
Here is a pic.
cheers
blinky :)
DJGM, blinkybill has posted his Opera browser screenshots over at the Neowin.net forums and the Opera forums. The skin in question is called LikeIE.
blinkybill is using a customized version of the LikeIE skin and a custom toolbar. You can get those two files here.
Here's what I did after closing Oprea:
  • [tt]1Internet Explorer 7 Beta 2.zip[/tt] goes in \skins\ directory in your \Opera\ directory ([tt]C:\Program Files\Opera\skin[/tt]).
  • Unzip [tt]standard_toolbar (1).zip[/tt] and insert [tt]standard_toolbar (1).ini[/tt] into your Opera profile, which should be [tt]C:\Documents and Settings\<username>\Application Data\Opera\Opera 9\Profile\toolbar[/tt] on Windows XP.
Then to change Opera's titlebar, type "opera:config" into the location bar, and in the "Quick find" field, type "title". In the "Title" field, type "Windows Internet Explorer." Click "Save."
In the end, you should get this:
Editing the titlebar:
Full size image.
About page:
Full size image.
Opera 9 rendering the Acid2 test (somthing IE7'll never probably do):
Full size image.
Note 1: I've never got around to uograding to Opera 9 final on my other PC, so all my screenshots are from a couple-week-old Opera 9 weekly build.
Note 2: The most recent configuration files blinkybill has provided are IE7 beta 2 files. blinkybill has created some IE7 beta 3 configs, but you'll have to contact hin for the files. I'm plenty sure he can explain all this better than I can.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1a3) Gecko/20060621 SeaMonkey/1.1a
Postby blinkybill » Sun 02 Jul, 2006 12:51 am
Hi DJM,
Once again you are wrong on your assumption that is a screengrab
of the latest Internet Explorer 7 Beta 3.
I also noticed you never took me up on the offer to recieve the skin
from me as proof that it can be done.
Again I am offering to send you the skin and toolbar.ini file.
I look forward to your reply. In the meantime here is the
screenshot you asked for.
http://img55.imageshack.us/img55/9797/p ... kin1ep.png
cheers
blinky
P.S. beanboy89 thanks for your input
UserAgent: Opera/9.01 (Windows NT 5.1; U; en)
blinkybill
Postby Pu7o » Sun 02 Jul, 2006 9:18 am
He's telling the truth. It is possible to make Opera look like IE 7, see this page for more information.
It doesn't look that good on Vista though...
UserAgent: Opera/9.00 (Windows NT 6.0; U; pt)
Postby Pu7o » Sun 02 Jul, 2006 9:43 am
Side-by-side comparison of Opera themed to look like Firefox, and Firefox 2.0a3:
http://kernel.ws/~puto/opera-vs-ff.jpg
Side-by-side comparison of Opera themed to look like IE 7, and IE 7 (on Vista):
http://kernel.ws/~puto/opera-vs-ie7.jpg
Opera themed to look like IE 6 (I don't have IE 7, so I can't do a comparison):
http://kernel.ws/~puto/opera-ie6.jpg
Postby blinkybill » Sun 02 Jul, 2006 7:00 pm
Thanks Pu7o for your information also, so its seems
it is possible to skin Opera to look like just about
anything. For me I found Opera so much easier than
Firefox to skin.
So if either you Pu7o or beanboy69 want my skin
I will gladly send it to you.
Just message me with your email address and I will
send it.
cheers
blinky
blinkybill
Opera 9 skin
Postby blinkybill » Fri 21 Jul, 2006 4:50 am
Have done some minor changes to my theme. Added button on the toolbar
which will uses the icon from IE7 Beta 3 and will open Outlook Express
from Opera. The second change is on the status bar, which looks like the Google
Notebook but uses Opera Notes. Also I did some changes to the Back and Forward
buttons to make them more like IE7 looks.
http://img95.imageshack.us/img95/5364/i ... tedfp2.jpg
cheers
blinky :)
blinkybill
Latest Update
Postby blinkybill » Tue 10 Oct, 2006 8:44 am
Been doing some more updating on my skin with custom menus
and added the New Tab button on the toolbar.
I have also been changing the the toolbar buttons so now when
you hover over them or press them they have the same look as IE7 RC1.
http://img178.imageshack.us/my.php?image=ie7rc1uq9.jpg
cheers
blinky
UserAgent: Opera/9.02 (Windows NT 5.1; U; en)
blinkybill
IE7 Update
Postby blinkybill » Fri 13 Oct, 2006 9:45 am
Done some updating on my IE7 skin for Opera.
Here is the lates pic.
http://i10.tinypic.com/4518pb5.jpg
Added New Tab Button & blue bar underneath tabs as IE7.
Updated Custom Menu.ini and adjusted height and size of Tabs
Adjusted Quick Tabs and Tab List buttons so they now sit next to the Tab button.
Changed icons in Panels for Favorites Feeds and History.
Updated all toolbar buttons so they now have a hover and pressed look.
Plus numerous other tweaks and fixes.
cheers
blinky
blinkybill
Another Update
Postby blinkybill » Sat 14 Oct, 2006 8:59 am
Just a quick update on my skin with
the status bar now looking like the
IE7 status bar
http://i10.tinypic.com/2nv6w42.jpg
cheers
blinky
blinkybill
Return to Opera
