How to find full path of netscape.exe 8.0
Postby jackm » Fri 31 Mar, 2006 2:25 pm
I have install the Netscape (8.0). how can I find full path of Netscape.exe in windows regkey.
one way is in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Netscape.exe
Please let me know if there are different way to approuch it.
Thanks
Jackm
jackm
Postby Fulvio » Fri 31 Mar, 2006 3:02 pm
I never look in the Registry. What do you want to do with that information. A typical installation would show, on the hard drive, this path: C:\Program Files\Netscape\Netscape Browser\netscape.exe
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9a1) Gecko/20060331 SeaMonkey/1.5a
Postby Don_HH2K » Fri 31 Mar, 2006 4:45 pm
For the most part, that's the simplest way to do it. Your other option would be to right-click a shortcut and see where it's pointing to.
Alternatively, to simplify the process of reading the Registry, you can rig a script to read you the value of that registry key. Open up Notepad and copy the following into it:
WScript.Echo(WScript.CreateObject("WScript.Shell").RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Netscape.exe"))
Then save it as "nsversion.vbs". Now just double-click the file to figure out where netscape.exe is hiding. You can put it on your Desktop for easy access, or on a floppy or USB drive to take it around with you.
my goal is find defaul web browser.
Postby jackm » Sat 01 Apr, 2006 12:55 pm
how can I detect Netscape8.1 is set as defaul broswer and get full path of the broswer?
thanks for your reply,
Jackm
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.2; .NET CLR 1.1.4322)
jackm
Registered users: Google [Bot], James, Yahoo [Bot]
