Dell (desktop) Computers . . .
Postby DJGM » Fri 28 Apr, 2006 11:33 pm
NOTE:
This thread is split from a moderators-only discussion. The nature of Dell computers is suitable for general discussion.
And I have a strange feeling that a certain someone's gonna suggest you buy a Mac ... again!
:wink:
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.2; en-US; rv:1.8.0.2) Gecko/20060404 SeaMonkey/1.0.1
Postby Antony » Sat 29 Apr, 2006 4:07 am
DJGM wrote:And I have a strange feeling that a certain someone's gonna suggest you buy a Mac ... again!
:wink:
Image Apple Store
Please use SillyDog701's affiliated link when you need to order a new computer or getting some computing accessories. You can support SillyDog701 by ordering computers and downloading music through SillyDog701.
I think I shall add Dell affiliation as well.
Postby DJGM » Sat 29 Apr, 2006 5:14 am
Antony wrote:I think I shall add Dell affiliation as well.
NOOOOO !!!
Dell is the most evil computer manufacturer there is! And I'm saying that even though they've been
bundling Mozilla Firefox in the UK! But that doesn't make up for the fact that Dell is totally ignorant
towards PC build standards, by using proprietary (non-standard) PSU's and mainboards.
Postby Mandrake » Sat 29 Apr, 2006 7:06 am
So do HP, Gateway etc. Not that I'd ever buy a pre-built PC :wink:
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.2) Gecko/20060308 Supergecko Firefox/1.5.0.2
Postby DJGM » Sat 29 Apr, 2006 7:23 am
Out of all the main PC makers, Dell is by far THE worst offender for using non-standard components.
Postby Don_HH2K » Sat 29 Apr, 2006 9:51 am
That reminds me of my grandparents' PC, with the motherboard mounted on the left panel of the case rather than the right. A bit surprising when you go to add a PCI modem. Consequently, you need to insert PCI cards upside-down due to the nonstandard orientation of the board.
Building a laptop might be a good idea, though. In two weeks, AMD is set to roll out the Turion 64 X2 dual-core line for notebooks. By then, I'll see how much a barebones S1-socket motherboard goes for, as well as an X2 ML-46.
Anyway, my vote is opposed to the addition of Dell ads.
Postby Antony » Sat 29 Apr, 2006 10:30 am
Exactly, what's wrong with Dell? I can't see anything wrong with using self-designed mainboard (as long as it complied to standards).
My PC laptop was a Dell laptop, and it served well for me.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/418 (KHTML, like Gecko) Safari/417.9.2
Postby DJGM » Sat 29 Apr, 2006 10:31 am
It's not only the non-standard configuration of the mainboard that's the problem with Dell computers,
but also the PSU's and the way they're wired. Once a Dell PSU goes, just dare to replace it with a
standard, proper "off-the-shelf" PSU, and then count the seconds before the whole thing fries!
There was an article in a recent edition of MicroMart magazine about fixing a broken Dell computer.
The symptom ... "a stress crack in the motherboard around the ATX power connector, which had been
caused by this bizarre Dell designed hinged case."
... the total cost of fixing this came to UK£100.
A near total rebuild of the entire PC was needed! It was an almost entirely different PC by the end!
I'm sure the overall cost of that repair job, would've worked out considerably less, if Dell had done
the right thing, and not used any proprietary parts or configurations, for the sake of extra profits.
As Antony would say ... "It's unethical!"
:wink:
Postby DJGM » Sat 29 Apr, 2006 10:37 am
Antony wrote:Exactly, what's wrong with Dell? I can't see anything wrong with
Dell motherboards do NOT comply to PC build standards.
Postby Antony » Sat 29 Apr, 2006 10:38 am
PSU as in Power Supply Unit?
I can't see that's a big deal. The Power Supply Unit simply converts the power from Mains to the required voltage and current (in DC) and also in the correct frequency (in AC).
Most likely, the guy MicroMart magazine mentioned did not pick up a correct one that can provide the specified requirement.
Postby DJGM » Sat 29 Apr, 2006 10:43 am
Antony, you don't understand. Dell's desktop system power supply units are wired in such a way in that
when they fail, they CANNOT be replaced with a proper standard "off-the-shelf" power supply unit.
As for "the guy Micromart magazine mentioned" ... he's Mark Pickavance, one of their regular writers.
A paragraph removed by Antony, 30 Apr 2006
Postby Andrew T. » Sat 29 Apr, 2006 11:08 am
You contradicted yourself right there.
Antony wrote:My PC laptop was a Dell laptop, and it served well for me.
Laptop designs are proprietary either way!
UserAgent: Mozilla/5.0 (Windows; U; Win95; en-US; rv:1.8.0.2) Gecko/20060308 Firefox/1.5.0.2
Andrew T.
Postby DJGM » Sat 29 Apr, 2006 11:58 am
Here's the shortened online version of the MicroMart article I mentioned earlier.
MicroMart - Repairing a Dell Computer.
MicroMart article writer, Mark Pickavance wrote:After some hours of experimentation, I was able to lock it down to a stress crack in
the motherboard around the ATX power connector, which had been caused by this
bizarre Dell designed hinged case. Initially I had considered that it could be a PSU
problem, but that wouldn't have been an easy fix, because Dell in their infinite
profitability decided to use a non-standard positioning and space for the
supply, making it impossible to replace with an off the shelf PSU.
I'll see what I can do in posting a full copy of the article as soon as I can, possibly in PDF format.
Postby Antony » Sun 30 Apr, 2006 9:44 am
So, like HP, Dell does not like to let users to modify their PCs... but I still don't see anything wrong with Dell.
Postby DJGM » Sun 30 Apr, 2006 10:57 am
Antony wrote:So, like HP, Dell does not like to let users to modify their PCs . . .
It's an unfair consumer lock in. When parts fail, as they eventually do, you can only get new parts direct from the
original manufacturers, rather than from a local independent computer repair shop, as most people prefer to do.
I should know, since my last job was in a computer repair shop, as one of the technicians. More often than
not, parts typically tend to fail after the warranty has expired, meaning you end up having to pay well
over the odds for more replacement proprietary parts to get your system fixed.
While PC's from the likes of Dell may be cheaper to buy in the short term, they always cost more than they need
to in the long term. Advice that I always give anyone looking to buy a new PC, is to go to an independent PC
specialist, that can build computers with fully standard, non-proprietary parts. That way, at least you'll get
standard components to replace original components that may fail during the lifespan of the computer.
Antony wrote:. . . but I still don't see anything wrong with Dell.
You ought to try being a computer technician, and work on the bleedin' things for the poor saps that've bought
them! You'd soon change your tune about Dell systems, and realise what a complete nightmare they can be!
