Fetch 5.1 released
Fetch 5.1 released
Postby Antony » Mon 12 Jun, 2006 11:30 am
Fetch Softworks released Fetch 5.1, a well known FTP programme. This updated version is a Universal Binary, allowing it to run natively on PowerPC and Intel-based Macs. It also includes a Dashboard widget and Automator actions.
Fetch 5.1 is available from Fetch Softworks.
Fetch 5.1 is priced at US$25, free for Fetch 5 users or US$15 for Fetch 4 users.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/418 (KHTML, like Gecko) Safari/417.9.3
Postby Antony » Tue 03 Oct, 2006 8:55 am
Fetch Softworks released Fetch 5.1.1, an update to Fetch 5.1 which released in June this year.
What's new in this version:
  • Added support for SOCKS 5 password authentication
  • Fixed a bug that prevented Fetch from opening on case-sensitive file systems
  • Fixed a bug that prevented Fetch from opening on Mac OS X 10.3.9 when the BSD subsystem wasn't installed
  • Fixed problems importing shortcut files that include broken shortcuts
  • Fixed recent connections so they won't remember passwords that are not stored in the keychain
  • Fixed widget crash on some Intel-based Macintosh computers (including Mac Pros and iMac Core 2 Duos)
  • Fixed crash in Get Specified Fetch Items action on some Intel-based Macintosh computers (including Mac Pros and iMac Core 2 Duos)
  • Some Mac Pros shipped with Mac OS X 10.4.7 Build 8K1079, which includes a bug that causes Fetch 5.1 to crash when you open a connection; affected Mac Pros need to be upgraded to Mac OS X 10.4.8 in order to run Fetch 5.1.1 or later
  • Fixed inaccurate display of size of newly uploaded files when using SFTP
  • Fixed problems with the Upload Files action in Swedish
  • Fixed layout problems with the Rename Fetch Items action in Spanish
  • Fixed tab navigation in Set Fetch Item Permissions action
  • Fixed widget problems on Mac OS X Leopard Developer Preview
  • Fixed potential crash when editing hostnames in shortcut list windows
  • Fixed potential crash when setting URLs of shortcuts via AppleScript
  • Fixed crash when typing in a blank shortcut list window
  • Fixed inaccurate font size display for new shortcut list windows
  • Changed new shortcuts created with Make Shortcut to default to kind Folder, instead of kind Unknown
  • Added skEdit as a supported text editor
  • Fixed a problem that caused some GoLive files to be stuffed on upload
  • Fixed drawing problems with some toolbar buttons when reducing transfer window width
  • Fixed a problem where a Mirror document was saved with incorrect information after switching between local and remote tabs
  • Fixed a problem where the incorrect folder could be mirrored after switching between local and remote tabs
  • Fixed problems duplicating shortcut list windows with AppleScript
If you have a problem uploading large files (uploading stalls), please see this tip: reverse Fetching problem?
Fetch Softworks.
Fetch 5.1.1 is priced at US$25, free for Fetch 5 users or US$15 for Fetch 4 users.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/418.9 (KHTML, like Gecko) Safari/419.3
Registered users: Google [Bot], Majestic-12 [Bot], MSNbot Media
