by Fulvio » Mon 24 Jul, 2006 11:20 am
The moment that the Mozilla Corp. decided to split the program files into two parts, one of which is a GRE folder of Common Files|mozilla.org|GRE. There had been problems with a bug in NS7.1 which did not remove its GRE folder, making it impossible to start an installed 7.2. The problem can show up in different ways, as well. So, I decided to take a look at my GRE folder. I found three folders there. A 1.8.0.1, 1.8.0.2 and a 1.8.0.4. I was able to match the last one to Seamonkey1.0.2. What are the other two from? I don't have any other programs left, which are installed, if the GRE folders are related to a Mozilla, Netscape, Donzilla, or what have you? Why are the GRE folders separate from the program, and placed in the Common Files. What is "common" to them?
I think that I should be able to delete the first two folders. As I read them, the folders are of 01-30-2006, and 04-04-2006, respectively. The 1.8.0.4 folder matches the 05-16 date of Seamonkey1.0.2.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.4) Gecko/20060508 Hyperbee Firefox/1.5.0.4
