Opera 9.01 Released
Opera web browser and M2 mail client from Opera Software. (for Windows, Macintosh and Linux.)
Moderators: Edward, Mandrake
Opera 9.01 Released
Postby north450 » Wed 02 Aug, 2006 9:37 am
http://www.opera.com/download/
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.8.0.5) Gecko/20060721 SeaMonkey/1.0.3
north450
Postby Antony » Wed 02 Aug, 2006 10:06 am
Thanks North,
from http://www.opera.com/docs/changelogs/mac/901/ ,
Changes Since Opera 9.0
    User interface
  • Solved problems with error console popping up unrequested. Console Filter setting in opera.ini has been renamed to Error Console Filter.
  • Newsfeeds can be renamed again.
  • Right-click to save images no longer puts the file in the list of transfers.
  • Fixed problems with setting external source viewer path. Preference field no longer requires quotation marks if containing spaces.
  • Solved issue where Opera would get focus, but elements would not be activated when clicked while Opera was in background.
  • Search field now shows dropdown when using the down arrow key.
  • Using search from right-click menu remembers the last search engine used.
  • "Find" and "Find next" options no longer grayed out in source viewer "Edit" menu.
  • Typed-in history now disabled and cleared with visited history in preferences.
    Mail, messaging, and newsfeeds
  • Multiple IMAP backend improvements and bug fixes.
  • Improved speed in handling filters with large number of messages.
  • Fixed problem with recognition of uuencoded attachments.
  • Changed quoting colors in mail for improved readability/accessibility.
    Display and scripting
  • Solved letter-spacing issue in form fields when using zoom.
  • Fixed problem with some Chinese sites where clicking any link would trigger language-switching script.
  • Fixes to contenteditable support.
  • Fixed scripting issue causing embedded content not to appear.
  • META refresh works with javascript: URIs again.
  • Allow forms to be submitted if the default value of their inputs exceeds their own maxlength.
  • Solved problems logging on to the Internet banking services of Volksbank Raiffeisenbank.
  • XSLT: Added support for exls:node-set function.
    Plug-ins and Java
  • Allow Flash from other domain to access script in page; fixes problems with sites where
  • Flash pop-ups cannot be closed.
  • Fixed problems with direct embedding of URLs using the MMS and RTSP protocols causing some Web radios and media players to fail.
  • Fixed bug where Java Applet did not load when width and height set to 0.
  • Fixed problem where some Flash pages would not prompt users missing Flash to install.
    Miscellaneous
  • Multiple stability improvements. Fixes include issue described in this Opera advisory.
  • Solved refresh problem causing some frames pages to turn blank.
  • HTTP accept language now stated correctly, works with Hotmail and other localized Web services again.
  • Fixed automatic saving of cookies.
  • Solved upload problems with Imageshack and similar services.
  • Improved compatibility with Adobe Type Manager and better handling of large quantities of
  • installed fonts.
    Mac-specific changes
  • Dragging the config.xml file into Opera now correctly opens the widget.
  • Improved window focus behavior.
  • "Help" button in master password dialog no longer exits kiosk mode.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/418.8 (KHTML, like Gecko) Safari/419.3
Postby Fulvio » Sun 13 Aug, 2006 2:10 pm
Is this the one which came up offering to upgrade to Opera90.1?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.6) Gecko/20060728 Moonwasp Firefox/1.5.0.6
Return to Opera
