AMD vs. Pentium
AMD vs. Pentium
Postby DiscoFever » Sun 05 Nov, 2006 3:34 pm
A lot of PC games List pentium 4 as part of their system requirements to run the game.
A lot of systems have AMD processors. Does it make a difference?...if not what is the AMD equivalent to Pentium, is it Sempron or Athlon. I plan on getting my son a computer as a gift and all the games list Pentium 4. All my computers have been Dell's, now dell has the AMD processors too.
any help will be greatly appreciated.
UserAgent: Opera/9.02 (Windows NT 5.1; U; en)
DiscoFever
Postby Don_HH2K » Sun 05 Nov, 2006 4:18 pm
When companies specify a Pentium processor, it's often hard to understand exactly what is meant by the rating. In some cases, people use a Pentium processor line as a speed rating, while others actually refer to the optimizations on the processor. Speed is pretty straightforward: a P3 is faster than a P2, and a P4 is faster than a P3, and by the same means, an Athlon XP is faster than a regular Athlon, and an Athlon 64 is faster than an Athlon XP. An example of a case like this is Adobe's Photoshop Elements: the box states that it requires a P4, though it runs fine on a P2.
There are also different optimizations on both processors; the P4 has SSE2 extensions, and its AMD equivalent would be an Athlon 64 or higher. Meanwhile, a Pentium 3 or higher has SSE extensions, with an Athlon XP or higher being AMD's equivalent, and a Pentium 2 has MMX extensions and would require an AMD K6 or higher.
The Sempron is a lower-cost processor a bit like Intel's Celeron line. If you're looking to get the fastest, the Intel Core 2 currently outperforms AMD's equivalent (Athlon 64 X2/FX) chips, and they're a bit easier to find pre-assembled in PCs.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.2 x64; en-US; rv:1.8.1) Gecko/20061030 BonEcho/2.0 (mmoy CE K8N-X02)
Postby DiscoFever » Sat 11 Nov, 2006 10:09 pm
Thank's for your help...Don (DONZILLA!!)
DiscoFever
