adding RAM
adding RAM
Postby amanda » Mon 13 Nov, 2006 12:41 pm
How do I find what type of RAM to order to add? I have 4 slots with 2 256MB memory sticks in currently. Just don't know what type of speed, etc. I should be getting? I will order two more 256MB.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X Mach-O; en-US; rv:1.8.0.3) Gecko/20060426 Firefox/1.5.0.3
amanda
Postby Don_HH2K » Mon 13 Nov, 2006 3:32 pm
What type of RAM you have is largely dependant on what's in your PC. Could you provide a make/model number for it? From there, one could look for a manual somewhere online that specifies the memory technology and speed you need.
Second, you need to find out if your system can support more than the 512MB you have right now, and if so, whether or not it can support a full 1024MB (1GB) that you want. Usually that's specified in a manual as well.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.2 x64; en-US; rv:1.8.1) Gecko/20061030 BonEcho/2.0 (mmoy CE K8N-X02)
Postby PaulD » Mon 13 Nov, 2006 6:24 pm
If you bought your computer new, then the Owner's Manual that came with it should give you the specifications of type, and maximum supported memory.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.8) Gecko/20061025 Firefox/1.5.0.8
Postby Antony » Tue 14 Nov, 2006 4:29 pm
If you really have no clue, you can try to read the prints in the RAM, something like "PC2700".
Of course, you should get the RAM modules that have the same number of pins. If in doubt, you can take your RAM to computer shop and ask for assistance. If you plan to carry RAM with your, you should carry it in anti-static plastic bag, to avoid damage to it.
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en-US; rv:1.8.1) Gecko/20061010 Firefox/2.0
Postby amanda » Wed 22 Nov, 2006 8:38 am
Let's see. I had this computer built for me, so I don't have a manual. By looking at my system properties, there is a 3.00 GHz pentium 4, 2.99 GHz 512MB of RAM. Would there be a manual online that I could find to direct me on what I need to purchase?
thank you!!!!
amanda
Postby Antony » Wed 22 Nov, 2006 9:09 am
I assume it's built by a local computer shop (not a big chain store), if that's the case you are unlikely to get the detailed specification, unless you still have the specification sheet.
Are you able to remove one of the two memory stick and see if there's any label on it?
Or take two clear pictures of the RAM (both sides) and we can try to help. (Be aware of static charges when removing RAM.)
Otherwise, you can simply take your computer to the shop, and ask for the right RAM. (Just bring the computer would do, no need to carry mouse, keyboard and monitor or any other cables.) However, you will have less bargaining power if you take the computer with you.
