creating DMG with QuickDMG
Postby Antony » Fri 24 Nov, 2006 5:33 am
Mac OS X users should all be familiar with [tt].dmg[/tt], a commonly used disk image format used in Mac OS X. But how do we create it?
Apple provided Disk Utilities (in Mac OS X v10.3 or later (and in Disk Copy in earlier versions). Although the creation of [tt].dmg[/tt] is not that difficult, it's a bit complicated when using the tool provided by Apple.
Script factory provides a nice and free tool - QuickDMG - allows creating DMG with little effort.
To use QuickDMG, you can simply drag a file or a folder into QuickDMG application icon, then make a quick selection on which type of DMG you want to use. We recommend using the "UDIF zlib-compressed" (default one).
QuickDMG is not designed for creating a complicated or highly professional disk images, it is designed to be easy to use. It not just does a quick job, but also a good job.
One thing I like QuickDMG most is that I don't have to specify the Disk Image file size first (as required by Disk Utility.)
What's the benefit of making a [tt].dmg[/tt]? As Tetsuro pointed out, unlike ZIP or StuffIt archives, you can open the compressed disk image without expanding it first. And there's also another good reason to use [tt].dmg[/tt] instead of [tt].zip[/tt], you can annoy Windows users.
link: QuickDMG by Tetsuro KURITA.
QuickDMG is free and open source. Version 2.0.7 has just released.
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en) AppleWebKit/418.9 (KHTML, like Gecko) Safari/419.3
Postby Pu7o » Fri 24 Nov, 2006 5:39 am
You used HTML instead of BBcode in your post :wink:
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en-US; rv:1.8.1) Gecko/20061024 BonEcho/2.0 Macfox/0.1
Postby Antony » Fri 24 Nov, 2006 5:45 am
Pu7o wrote:You used HTML instead of BBcode in your post :wink:
Thanks.
Antony is old (and poor).
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en-US; rv:1.8.1) Gecko/20061010 Firefox/2.0
Postby Antony » Fri 24 Nov, 2006 10:42 pm
Just a gentle reminder, if you do provide [tt].dmg[/tt] for download, you might want to add following line to [tt].htaccess[/tt], as most web hosting providers do not have the correct MIME type for [tt].dmg[/tt].
AddType application/octet-stream .dmg
Side note: when you add MIME type for [tt].dmg[/tt], you might also want to add MIME type for [tt].mp4[/tt] for H.264 movie you made :-) ([tt].mp4[/tt] is not usually specified in web servers by default.)
AddType video/mp4 .mp4
Registered users: Google [Bot], James, Yahoo [Bot]
