The Fix:
From the Netscape site the issue is around accessing ns8-stats.netscape.com
I added a host entry to the hosts file as follows:
1) Open a command prompt.
3) Use notepad and edit the hosts file in the windows directory. C:\windows\system32\drivers\etc\hosts .
There is no extension on this file.
4) Add the line "127.0.0.1 ns8-stats.netscape.com" without the quotes
5) Save the hosts file.
6) Restart Netscape.
There were several other ways reportedly to fix this, but this seemed to address my issue without breaking anything.
BTW, rumor is that 8.1.3 is about to be released (April) and that a Netscape 9 is planned by end of the year.
Previous Post: I have done enough troubleshooting to understand the manifestation of the problem, but no idea what is causing it. If you bring up Task Manager, sort by CPU descending, and watch, this is what you will see. You can set your watch by it. For one minute Netscape 8.1.2 works just fine, then for one minute it goes into a 99% CPU utilization. Whatever it is doing freezes any activity. This cycle continues indefinitely, no apparent growth in memory usage. As others have stated, this just started recently, so it is some kind of software update to Windows XP. I do not think it was from this last patch Tuesday because I do not allow automatic updates. I like to review them before they are installed. The problem existed before I installed the patches. However, Symantec Internet Security could be implicated. I have not tried to see if it is, but it updates automatically. I had the problem at a lower JRE and also at the current level. I have not tried removing it to see if that corrects the issue.
This is really annoying. Netscape 8.1.2 is a much better implementation than Firefox 2.0 for my purposes. I hope the Netscape boys are aware of this issue and do fix it or at least identify the culprit and a workaround.
Hope others can confirm the CPU usage cycle.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.1) Gecko/20061204 Firefox/2.0.0.1
