Note at the top of
the file you reference:
Written with Windows 9x in mind, but not limited to.
DISCLAIMER:
I will not be liable for any damage or lost information, whether due to reader's error, or any other reason.
Hence the instructions must be modified for Windows XP (and probably 2000 and NT). The command sets available in the various versions are
generally compatible, but not identical. The article was written in 2001.
1. Before you go any farther, read through the reference thread given in the line above the article title: [sdt=3514]How to access hidden temp files[/sdt].
2. Yes, as an Administrator you have maximum authority to destroy things.
3. Safe Mode with Command Prompt is the equivalent you want.
4. The "bunch of their stuff" probably is the 'current path' (directory).
Key in
PROMPT /? to see what all is available.
What you are seeing is the default PROMPT $P$G.
5. XP does not have DELTREE, since the DEL command has been enhanced.
Key in
DEL /? to see functionality and syntax.
6. Folder and file names and locations almost certainly have changed. You will have to trace out the equivalents on your system - and locate them for each user-ID.
7.
What should I be doing so I can delete all of these files, cookies etc?
Once you've gotten there (really, don't wait; do it now), switch over to using Mozilla-based products. All files are displayable/deletable at your pleasure: nothing hidden up the sleeve.
8. You will still need IE for those sites that are archaic or stubborn to change. Enlighten them to the facts of internet life. Don't try to remove IE itself, portions of it are required for Windows to operate.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.8) Gecko/20061025 Firefox/1.5.0.8
