send SMS from your Mac (with your mobile)
Postby Antony » Sun 17 Dec, 2006 11:34 am
Mac is smart
Many Mac users know that it is very easy to use iSync to link Bluetooth mobile for syncing calendar (iCal) and contact list (Address Book). In fact, you can also send text messages (SMS) via your linked Bluetooth phone directly from your Mac. It's built-in, you don't need any other software.
Once you paired your Bluetooth mobile to your Mac, all you need to do is switch on the Bluetooth on your mobile, then click the Bluetooth bottom on your Address Book as shown in picture below:
Next select the person you want to contact, and click on the "mobile" (or "home" or any label next to the phone number, you should see a pop-up similar to below:
Just select SMS, and you can send Text Messages (SMS) directly from your Mac.
What is the benefit of doing so? Typing on a full sized keyboard is always much easier than using the numerical keypad for input, and sometimes it's easier to find the person on Address Book or the person's number is not on your mobile yet.
As you can see from the screenshot above, it is also possible to use the Mac (via Address Book) to dial the number. Mac is smart.
If your mobile is Sony Ericsson D750, K750 and W800, you will need to follow this quick instruction before you can use your mobile phone directly from Address Book.
(You will need a Mac with Bluetooth and a Bluetooth enabled mobile phone.)
For more information about Bluetooth, please visit this page.
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en) AppleWebKit/418.9.1 (KHTML, like Gecko) Safari/419.3
SMS
Postby hagheid » Mon 18 Jun, 2007 2:47 pm
Eventually got this to work; Some incompatability with my Motorola SLVR was the problem. I used a friends Samsung & managed to get the Bluetooth symbol on the address book to actually turn blue....
The air then quickly turned blue when it became obvious that the SIZE of message is restricted!!!!
The permissable size is so small that it would be quicker to revert to the fingering than bugger about with Macs, address book etc.
Well WHAT is the point of this? The main use of SMS via Mac is surely to remove the need for this hugely tedious verging on the moronic phonepad input?
Anyone have a better solution?
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/419 (KHTML, like Gecko) Safari/419.3
hagheid
