PRO TOOLS LE AND REASON PROBLEMS
Postby Heaterville » Fri 12 Jan, 2007 12:09 pm
HEY WHASSUP EVERYBODY AND ANYBODY THAT CAN HELP ME.... RECENTLY MY PRO TOOLS LE 6.4 (DIGI 002) HAS BEEN CRASHING SO I TRIED TO UPDATE TO 6.7 USING A DISK MY FRIEND HAD GIVEN ME... WELL I TRIED UPDATING TO THAT AND THEY WANTED A AUTHORIZATION CODE AND THE CODE I HAD FOR THE 6.7 WASNT WORKING!! SO NOW IM TRYING TO GO BACK TO 6.4 AND THAT WONT WORK EITHER BECAUSE I DONT HAVE THE AUTHORIZATION CODE!! AND ON TOP OF THAT... I TRIED TO OPEN REASON AND ITS OPENING LIKE ITS BRAND NEW!! TELLING ME TO INSERT ORKESTER CD LIKE IT WANTS TO INSTALL IT ALL OVER AGAIN... I DONT KNOW WHAT THE PROBLEM IS BUT I NEED HELP REALLY REALLY BAD ASAP!!!!
THANK YOU
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/312.1 (KHTML, like Gecko) Safari/312
Heaterville
Postby Don_HH2K » Fri 12 Jan, 2007 6:08 pm
I'M GLAD TO SEE I'M NOT THE ONLY ONE WITH A BROKEN CAPS LOCK KEY. :wink:
If you can't find the authorization code that you got when you purchased Pro Tools 6.4, I'd advise that you contact Digidesign by phone or e-mail, and explain your situation. If you registered your copy of Pro Tools, or if you bought straight from Digi, then I'd bet they have your license key on file, or they might be able to give you a new one if you can confirm that you bought Pro Tools.
I'd advise that you stick with a fresh install of Pro Tools 6.4, since from what I gather, when you tried to upgrade to 6.7, Pro Tools detected that you were using a license key from an older version of the app and didn't accept it. I think that Digi charges for each additional update to the Pro Tools software, thus your license incompatibility.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.0 x64; en-US; rv:1.8.1) Gecko/20061030 BonEcho/2.0 (mmoy CE K8N-X02)
Registered users: Google [Bot], MSNbot Media, Yahoo [Bot]
