" Which External HDD Should I Buy? "
Postby rgarr » Sun 14 Jan, 2007 1:37 pm
I'm using Win XP SP and I'm looking for an external HDD to back-up all my data, files, photos. and music...basically all of C: drive for about $150 or less.
My other reason for wanting the external HDD is that after I transfer all of my C: drive and important files from my Dell desktop I plan to reformat the Dell desktop and do a clean install then transfer everything back from my external HDD to my desktop.
I have looked at Iomega 33215 250 GB External Hard Drive on Tiger Direct and read the reviews but I am interested in getting your opinions.
I understand that if I get this HDD I will have to reformat from Fat 32 to NTFS. Is this hard to do? I appreciate any suggestions and opinions from those of you who have been there and done this...thanks in advance!
__________________
UserAgent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 2.0.50727; .NET CLR 1.1.4322)
rgarr
Re: " Which External HDD Should I Buy? "
Postby Don_HH2K » Sun 14 Jan, 2007 1:53 pm
rgarr wrote:I understand that if I get this HDD I will have to reformat from Fat 32 to NTFS. Is this hard to do?
It's not hard at all. Open up My Computer, right-click on the external dive, and select Format. It'll ask what file system you want, make sure NTFS is selected and then format away.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.0 x64; en-US; rv:1.8.1) Gecko/20061030 BonEcho/2.0 (mmoy CE K8N-X02)
Postby rgarr » Sun 14 Jan, 2007 3:08 pm
Thanks "Don_HH2K",
I appreciate the advice and help with this! I didn't know it was that easy.
rgarr
Postby Antony » Sun 14 Jan, 2007 8:19 pm
Hello rgarr,
The thing you should be consider is which one works for you. Using USB2 or FireWire 400. Theoretically, USB2's data rate is a bit faster than FireWire 400 (480 Mbits/sec vs 400 Mbits/sec). However, in reality, FireWire 400 ones usually performs better than USB2 external hard disks (and usually costs a bit more).
You can format the external hard drive into any file system you wish (as Don mentioned.)
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en-US; rv:1.8.1.1) Gecko/20061204 Firefox/2.0.0.1
Postby rgarr » Sun 14 Jan, 2007 11:32 pm
Antony wrote:Hello rgarr,
Thanks Antony,
I appreciate the added advice! I think I'll go for the USB2
rgarr
