Sepialise Me, apply sepia tone to your photos!
Moderator: Don_HH2K
Postby Antony » Thu 01 Mar, 2007 12:23 am
I am pleased to announce the public release of Automator Action -
Like the good old fashion style? As the name suggested, this Automator Action will apply sepia tone (effect) to your photos, and it's very easy to use, just do it the Mac way - drag-and-drop.
To use it, simply download Sepialise Me (free from MacCentre701).
Then drag your images or photos to the Sepialise Me icon.
You can get results like this:
For more information and to download Sepialise Me (Automator Action), please visit Sepialise Me page.
(PS. That is Antony in the photo above.)
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en) AppleWebKit/418.9.1 (KHTML, like Gecko) Safari/419.3
Postby Antony » Fri 02 Mar, 2007 4:57 am
No takers?
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en-US; rv:1.8.1.2) Gecko/20070219 Firefox/2.0.0.2
Postby djv1 » Fri 02 Mar, 2007 2:33 pm
i would take it for windows if you are willing to make it
Dustin
djv1
Postby Don_HH2K » Fri 02 Mar, 2007 3:46 pm
djv1 wrote:i would take it for windows if you are willing to make it
Working on a .NET Framework port right now, started this morning. Of course with classes and all that hasn't given me much time to work with it yet. :(
I have no idea how to use GDI+ to do this sort of thing, so I'm borrowing the sepia code from the open-source Paint.NET. Apparently it isn't too hard since SepiaEffect.cs is less than 2kb in size.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.2; en-US; rv:1.8.1.2) Gecko/20070225 BonEcho/2.0.0.2 (tete009 G7 SSE2)
Postby Don_HH2K » Fri 02 Mar, 2007 6:50 pm
My .NET Framework 2.0 port is done so that you can run (something like) this on Windows platforms. It's written in C#, and supports sepialising the following file types: BMP, JPEG, PNG, GIF, TIF, WMF, and EMF (i.e. everything that GDI+ supports). It should run without problems on Windows 2000 and higher; 98 and ME users might need to install it manually.
To use the .NET version of Sepialise Me, you will need to go download the .NET Framework 2.0 or higher if you haven't already or haven't received it through Windows Update. Windows Vista users do not need to download the .NET Framework, as it comes included with Vista.
You can download Sepialise Me binaries here (2kb). To install, extract the contents of the ZIP file and double-click [tt]install[/tt] or [tt]install.cmd[/tt]. The source of sepialise.cs is available here if you want to play around with it.
My version of Sepialise Me is a bit different from Antony's in a few ways. First off, rather than using a drag-and-drop, you only need to select the file(s) you want, then right-click and hit Sepialise Me, as shown below:
It saves files in the JPEG format in the same folder and appends "_sepia" at the end of the filename. For those interested Sepialise Me installs itself on your %PATH%, so you can run it using [tt]sepialise[/tt] in batch files or on a command line. Using this method it should run on Windows 98/ME as well as other operating systems using the free Mono framework.
On average I've found this to be pretty fast - it processes a folder full of sixteen 640x480 JPEG images in roughly a second and a half on my machine. Feel free to share your results.
Postby Pu7o » Fri 02 Mar, 2007 11:46 pm
Sorry, it's not mono-compatible, Mono doesn't have System.Drawing yet.
[puto@iMac ~/Desktop]$ mcs sepialise.cs
sepialise.cs(2,7): error CS0234: The type or namespace name `Drawing' does not exist in the namespace `System'. Are you missing an assembly reference?
sepialise.cs(2,1): error CS0246: The type or namespace name `System.Drawing' could not be found. Are you missing a using directive or an assembly reference?
    Try using -r:System.Drawing
sepialise.cs(3,7): error CS0234: The type or namespace name `Drawing' does not exist in the namespace `System'. Are you missing an assembly reference?
sepialise.cs(3,1): error CS0246: The type or namespace name `Drawing.Imaging' could not be found. Are you missing a using directive or an assembly reference?
Compilation failed: 8 error(s), 0 warnings
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en) AppleWebKit/419 (KHTML, like Gecko) Safari/419.3
Postby Don_HH2K » Fri 02 Mar, 2007 11:50 pm
Okay, forget I ever said it was Mono-compatible.
Postby Pu7o » Fri 02 Mar, 2007 11:53 pm
Partially ignore my earlier comment; Mono does indeed have System.Drawing. Still, this doesn't work on Mono.
[puto@iMac ~/Desktop]$ mcs sepialise.cs -r:System.Drawing
[puto@iMac ~/Desktop]$ mono sepialise.exe
Unhandled Exception: System.IndexOutOfRangeException: Array index is out of range.
  at Sepialise_Me.Program.Main (System.String[] args) [0x00000]
** ERROR **: file mini.c: line 8604 (mono_get_lmf_addr): should not be reached
aborting...
Stacktrace:
** (process:2037): ERROR (recursed) **: file mini.c: line 8588 (mono_get_lmf): should not be reached
aborting...
Abort trap
EDIT again: I'm a complete idiot. This DOES work on mono. I just forgot to pass an argument to the thing. :roll:
Postby Don_HH2K » Fri 02 Mar, 2007 11:57 pm
Uh.. Perfect?
Postby Antony » Sat 03 Mar, 2007 7:05 am
Don_HH2K wrote:On average I've found this to be pretty fast - it processes a folder full of sixteen 640x480 JPEG images in roughly a second and a half on my machine. Feel free to share your results.
Excellent, do you have before and after outputs of a picture of yourself?
Postby Antony » Sat 03 Mar, 2007 7:30 am
Thanks guys for your interesting on porting to other platforms.
Do we have any feedback on Sepialise Me (Automator Action), the one that works directly on Mac OS X 10.4?
Perhaps SillyDog701 members are not that interested on Sepialise Me (Automator Action) I wrote, but Apple does. In this Apple Mac OS X Download page (under Automator Actions section), it seems that Apple likes it.
Postby khimkhoykhi » Sat 03 Mar, 2007 4:31 pm
Wow, one cool App! Like you said, it's as easy as drag and drop.
Thanks for sharing Antony, as always.
(nice photo you have there in the Apple website)
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/418.9.1 (KHTML, like Gecko) Safari/419.3
khimkhoykhi
Postby Antony » Tue 20 Mar, 2007 8:38 am
I just noticed that Sepialise Me has been listed in Softpedia, and has the "100% clean" thing.
(I did not submit the file there.)
Postby Antony » Sat 06 Dec, 2008 3:02 am
Sepialise Me 1.1 is now available.
Version 1.1 added compatibility to Mac OS X 10.5 "Leopard".
Sepialise Me 1.1 requires Mac OS X v.10.5.x 'Leopard'. Mac OS X v.10.4.x users can still download version 1.0 from this page.
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.5; en-US; rv:1.9.0.4) Gecko/2008102920 Firefox/3.0.4
Re:
Postby wdf2020 » Mon 31 Oct, 2011 6:05 pm
Antony wrote:Sepialise Me 1.1 is now available.
Is there going to be a version for OS X 'Lion'? :)
UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/535.2 (KHTML, like Gecko) Chrome/15.0.874.106 Safari/535.2
wdf2020
Return to SD701 DevZone
Registered users: Exabot [Bot], Google [Bot], Yahoo [Bot]
