Netscape Version 8.1.2 Find lost Bookmarks?
Postby Mancala » Wed 07 Mar, 2007 11:05 pm
Hiii,
My computer crashed and will sort of load, however, all the netscape setting apear to be gone and it is set up like I just installed netscape for the first time. How would I get my bookmarks back does it save it in like a temp file or anything?
I would be very very very very greatful! Thanks sooo much!
UserAgent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30)
Mancala
Postby Fulvio » Thu 08 Mar, 2007 2:45 pm
You may or may not know that the Profiles are hidden in Win XP. So take a look if you have a Netscape profile folder with the path given. If there is a folder there, you could modify the Target line of your shortcut, by adding -p default, with keyboard space before -.
If there is nothing in that folder, you should uninstall it, and reinstalled it, having allowed the program to delete the profile. But, probably this is what you are experiencing now. If you don't have a backup of the file, you are out of luck. Are these totally new bookmarks, or were they imported from some other program?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.10) Gecko/20070216 Firefox/1.5.0.10
Registered users: Anonymosity, Google [Bot]
