MPEG2 file format is not showing in the file format
Postby kishorilal2k2 » Sat 30 Jun, 2007 6:27 am
hi
i am using final cut pro 5.1 , when convert my fcp movie in to mpeg2 using export-ouicktime convertor, the mpeg2 file format is missing on the list at the same time all other format are showing, how to enable the mpeg2 file format in the list
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.2; SV1; .NET CLR 1.1.4322; .NET CLR 2.0.50727)
kishorilal2k2
Postby Fulvio » Mon 16 Jul, 2007 11:04 am
I suggest that you do a Search. You will need to download a codec.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.4) Gecko/20070515 Firefox/2.0.0.4
