Beware: Navigator9.0b3 is out
Postby Fulvio » Thu 16 Aug, 2007 3:59 pm
My settings were to ak me what to do, but b3 started downloading the entire file.
At least, it listened to me when I chose to restart 9.0b2 later.
The Netscape page alleges full extention compatibility with Firefox2 something (unspecified).
I have had MediaPlayerConnectivity forever, and ColorfulTabs for quite a while, but they were declared incompatible. No problem thanks to NightTesterTools.
Just enough to be annoying.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.7pre) Gecko/20070815 Firefox/2.0.0.6 Navigator/9.0b3
Postby Antony » Thu 16 Aug, 2007 8:18 pm
Thanks for informing us, Fulvio.
This is the first Netscape 9.0 Beta I've ever installed myself. My quick impression so far is positive.
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en-US; rv:1.8.1.7pre) Gecko/20070815 Firefox/2.0.0.6 Navigator/9.0b3
Postby Ginkan » Fri 17 Aug, 2007 3:36 am
Antony wrote:Thanks for informing us, Fulvio.
yes, finally my Netscape can update and install itself
Ginkan
Postby Fulvio » Fri 17 Aug, 2007 10:19 am
I said Beware because Antony had been indignant when Firefox did exactly that, i.e. updating and installing itself. I, never, had the problem exhibited by NS9b3, which went on to download itself, while I was doing something else. I could not do anything while it was downloading the entire file, and then the installation occurred on startup.
I was never asked what to do, as my settings were.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9a8pre) Gecko/2007081312 SeaMonkey/2.0a1pre
Firefox themes do not work..
Postby mpowell1234567890 » Fri 17 Aug, 2007 2:08 pm
Firefox themes do not work.. I tried installing them but I get a incompatibility error..
Is there a way to fix it? Is there a patch that will fix it?
Michael Powell
mpowell1234567890
Postby James » Fri 17 Aug, 2007 3:29 pm
It's beta, guys. You have to recognize that it's just not going to work the way a final release will.
UserAgent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727)
Postby Fulvio » Fri 17 Aug, 2007 8:40 pm
I am using Nightly Tester Tools as aid to avoid compatibility checks. It has worked pretty well.
Some addons have given me errors, but nothing that I could not operate.
As James said, it is still beta, and, the developers are managing to mess up, sometimes.
As for Addons, contrary to what is, genrally, thought, it is not up to the program to make the Addons compatible., but the other way around.
Still, I, and others who have had Addons installed, have had reports that the Addon was not compatible (I got four out of eight treated that way). I just ignored that, and the Addons worked. At this point, they are still messing with the Firefox base, and some problems do crop up.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9a7) Gecko/2007080210 GranParadiso/3.0a7
Re: Nightly Tester Tools.
Postby mpowell1234567890 » Mon 20 Aug, 2007 2:57 am
Idid try that, but I get the invalid page error. It even happens when I press use theme on the default theme.
UserAgent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.0.3705; .NET CLR 1.1.4322; Media Center PC 4.0; .NET CLR 2.0.50727; .NET CLR 3.0.04506.590; .NET CLR 3.5.20706)
Michael Powell
mpowell1234567890
Postby richard mitnick » Mon 20 Aug, 2007 3:38 pm
Gee willikers,
Hey, you guys, how is everyone?
I did the update on all four computers, which no problems. I just started .09beta2, nothing happened, I went to check for updates, I found the update, it took about 20 seconds. I think that I did need to re-start the browser in each case, but that was it. I don't have much in the way of extensions, just IETab and Colorful Tabs.
>>RSM
New Jersey weather: soggy, feels like Fall, but Summer is coming back later in the week.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.0; en-US; rv:1.8.1.6) Gecko/20070725 Firefox/2.0.0.6
richard mitnick
Re: Firefox themes do not work..
Postby macallan1824 » Mon 20 Aug, 2007 4:11 pm
mpowell1234567890 wrote:Firefox themes do not work.. I tried installing them but I get a incompatibility error..
Some of the new NN9 function means new theme resources are needed to support the new toolbar & statusbar icons, sidebars, etc. Hence Firefox 2 themes need some modifications to support NN9, they rarely seem to work otherwise....
You can find a selection that do work with the NN9 betas here.
Note: these themes currently use the default NN9 beta theme versions of the new resources
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.0; en-US; rv:1.8.1.7pre) Gecko/20070815 Firefox/2.0.0.6 Navigator/9.0b3
macallan1824
Re: Beware: Navigator9.0b3 is out
Postby macallan1824 » Mon 20 Aug, 2007 4:31 pm
Fulvio wrote: The Netscape page alleges full extension compatibility with Firefox2 something (unspecified).
Some FF extensions support Netscape 8, and hence have a Maximum Supported Version for Netscape of 8.1.2 or 8.1.3 etc.
In this situation, as NN9 uses the same ID as NS8, the extension fails the Netscape Version Check. This is unfortunately necessary, as the extension may only be designed to work with NS8. (i.e. an FF 1.0.x based extension)
If however, a FF2 extension has never supported NS8, it has no ID entry for NS8/NN9, and in this case NN9 allows it to install.
i.e. NN9 overrides the problem caused by this missing ID section.
So, if you get an extension install error, use an extension that allows you to override the problem, but also e-mail the extension author and request NN9 support, with enough requests, hopefully we can all benefit.
macallan1824
Postby Fulvio » Mon 20 Aug, 2007 5:57 pm
If you may, take a look at the extention compatibility thread at ufaq.org.
Briefly, although some extentions may be called incompatible, they work fine. Maybe the developers have to refine this point. However, I found that the Forecastfox extention was giving me errors, no matter what. Jay Garcia made some changes in the extention, and I still got errors. Finally, after removing any Forecastfox extention, I launch a search and destroy mission, which yielded several lines of Forecastfox in files like localstore.rdf (unexpected), or prefs.js (expected). After editing everything, the extention was installed.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.6) Gecko/20070725 Firefox/2.0.0.6
Postby jjssparkle » Sat 25 Aug, 2007 9:20 am
(Chuckle) Just a suggestion: Don't go experimenting with experimental softwares (betas and alphas) on your primary machine if you've got an old secondary machine booted up somewhere in the house ...
jjssparkle
Postby Fulvio » Sat 25 Aug, 2007 10:52 am
jjssparkle wrote:(Chuckle) Just a suggestion: Don't go experimenting with experimental softwares (betas and alphas) on your primary machine if you've got an old secondary machine booted up somewhere in the house ...
There is nothing wrong with beta software (usually). and, I have tried all sort of stuff with no damage.
Your suggestion is reasonable if you have a secondary machine, in first place, or, at least hooked up to the Internet. It costs more to have two machines hooked up, also, you know.
