Commander Keen & DOSBox
Postby nikolette » Tue 23 Oct, 2007 2:55 pm
Okay, I recently asked this on another forum and got some smart-alec answer. Hopefully someone here can help. I recently downloaded DOSBox (v.72, Mac compatible) and an .exe file of Commander Keen. It is a LEGAL, shareware copy (I didn't state that in my post on the last forum and they got in my face about it). I'm trying to figure out how I can run it directly from my hard drive through DOSBox. When I open DOSBox it tells me I need to mount the drive that the file is in (I'm not running it from my CD drive), but I'm not exactly sure how to do that. Any ideas/answers?
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/419.3 (KHTML, like Gecko) Safari/419.3
nikolette
Postby Mandrake » Tue 23 Oct, 2007 11:55 pm
I don't regularly use a Mac, but I do use DOSBox frequently.
To mount a directory in DOSBox one uses the following syntax:
[tt]mount X: [directory path][/tt]
Where X is the letter of the drive you'll want to mount. In most cases this will be C:. The only time you need to worry about other drive letters is when dealing with mounting CDs or DVDs (which are another matter entirely).
[directory path] refers to where the the game is stored on your local hard disk.
In Windows, a typical mount command might be:
[tt]mount C: c:\oldgames\doom[/tt]
On OS X (I think I have the syntax correct) you'd be using:
[tt]mount C: ~/oldgames/doom[/tt]
Of course, this depends on where you've stored the game. If the directory path has spaces in it, I believe you need to wrap the whole thing in "s. i.e.
[tt]mount C: "~/old games/doom"[/tt]
Also keep in mind that OS X (unlike Windows) is case sensitive. The path needs to be identical in this respect or it won't work.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.8) Gecko/20071008 Firefox/2.0.0.8
Postby Pu7o » Wed 24 Oct, 2007 10:14 am
Actually no, OS X isn't case-sensitive, not by default anyway.
UserAgent: Mozilla/5.0 (X11; U; Linux x86_64; en-US; rv:1.8.1.8) Gecko/20071022 Ubuntu/7.10 (gutsy) Firefox/2.0.0.8
Postby Mandrake » Wed 24 Oct, 2007 12:32 pm
Pu7o wrote:Actually no, OS X isn't case-sensitive, not by default anyway.
I stand corrected. Thanks. :)
Postby nikolette » Wed 24 Oct, 2007 11:27 pm
Thanks so much, that helps a ton! :) Just to double check, on the Mac OS X, C: is what refers to my hard drive?
nikolette
Postby Antony » Wed 24 Oct, 2007 11:48 pm
nikolette wrote:Thanks so much, that helps a ton! :) Just to double check, on the Mac OS X, C: is what refers to my hard drive?
In most cases, you can just use [tt]/[/tt]. Otherwise, it depends on what you name the main hard drive. For example, if it is called "[tt]Mac OS X[/tt]", then you can specify it as [tt]"Mac OS X"[/tt] (using quotes) or [tt]Mac\ OS\ X[/tt] (using [tt]\[/tt] before space)
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en-US; rv:1.8.1.8) Gecko/20071008 Firefox/2.0.0.8
