Force Quitting
Force Quitting
Postby appleguy07 » Thu 06 Dec, 2007 1:49 am
I own a Mac OS X. When programs aren't responding, I immediately use the Force Quit option to end the program, and restart it.
Does this process eventually damage the hard drive?
Is there an alternative solution to programs not responding?
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en) AppleWebKit/523.12 (KHTML, like Gecko) Version/3.0.4 Safari/523.12
appleguy07
Postby iJohnE » Thu 06 Dec, 2007 6:52 am
Usaully when prgograms don't respond in Mac OS X there is a bigger problem. What exactly happens when they don't respond, do you get "The Volley Ball Of Death" or does it simply just stop working. Maybey, you have too many things installed on you Mac, I'd recommend going through and uninsttalling useless programs. Also, programs that do not respond frequently, may have to be re-installed.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.0; en-US) AppleWebKit/523.12.9 (KHTML, like Gecko) Version/3.0 Safari/523.12.9
Re: Force Quitting
Postby Antony » Thu 06 Dec, 2007 7:13 am
appleguy07 wrote:I own a Mac OS X. When programs aren't responding, I immediately use the Force Quit option to end the program, and restart it.
Well, sometimes, if you wait for a while, the application might be back to responsive. If in such case, it means that there was far too much data or system resource being used by the app itself, rather than to interact with users.
appleguy07 wrote:Does this process eventually damage the hard drive?
No, but your [tt].plist[/tt] files might get damaged.
appleguy07 wrote:Is there an alternative solution to programs not responding?
Reporting to the developers, and see if there's an update to the applications that has better compatibility with the OS.
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en; rv:1.8.1.11) Gecko/20071128 Camino/1.5.4
