Seamonkey 1.1.8 Released.
Postby captjlddavis » Thu 07 Feb, 2008 9:27 pm
Seamonkey 1.1.8 released
http://www.seamonkey-project.org/
http://www.seamonkey-project.org/news#2008-02-07
regards:captjlddavis
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.12) Gecko/20080201 SeaMonkey/1.1.8
captjlddavis
gold member
gold member
Postby Fulvio » Fri 08 Feb, 2008 1:02 pm
As I posted at another newsgroup, Seamonkey, since v.1.1.11 has done one weird thing, more than once, with different builds, and different profiles.
If I open one site, from my bookmarks, like this one, and have more than one Tab, and use the left most tab, it will keep the original URL, although it will open the desired page. This does not happen with the second, or third Tab. It will show the correct URL, but if I go back to Tab 1, the URL will be the same which was last opened, and, in one case, I could not even close that window. But, if I select to open Tabs instead of windows, from links, I can open a new Tab from bookmarks. None of the other Tabbed Browsing settings matter. So, now, I have the three original Tabs, plus Sillydog's to the far right.
I had SM1.1.8RC, from a nightly, and, it behaved for two days, with a brand new profile. I deleted the unzipped file, but, then I download the final version, and usesd the same profile. It worked once, and, it is back to its old tricks. Any way, SM is usable, but I have to change my habits.
Should anyone care this behavior has been verified by only two other people that I know of.
I will check mozillazine, again.
Postby Edward » Sat 09 Feb, 2008 8:06 pm
Fulvio,
I would file a bug on the problem you are having. This way, with the information provided, they can look into it.
I attempted to duplicate with the Linux version, what you are describing, without success.
UserAgent: Mozilla/5.0 (X11; U; Linux i586; en-US; rv:1.8.1.12) Gecko/20080201 SeaMonkey/1.1.8
Postby Fulvio » Sun 10 Feb, 2008 5:40 pm
Someone at mozillazine.org suggested that it may be due to an extention.
I was using only seven extentions, plus the extention uninstaller, and its .api.
So, I removed all extentions, except for the uninstaller. There was no Tab problem. Then, I started adding back the extentions, and as soon as added Mr Tech Local Install, I had problems. All other extentions were fine, i.e the home button, prefbar, IE tab, colored tabs, mediaplayerconnectivity, and Yahoo Mail notifier. I don't need the Mr Tech.
Postby Edward » Sun 10 Feb, 2008 6:38 pm
With a name like "Mr Tech", what does it do?
UserAgent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.8.1.12) Gecko/20080201 SeaMonkey/1.1.8
Postby Fulvio » Mon 11 Feb, 2008 12:27 pm
Edward,
I am using it, only to by-pass the compatibility check. Some extentions can be installed, but don't work, as they are not compatible. It is useful to use something like Mr Tech with nightlies, or unreleased final versions. I reported the issue for the extention.
A simpler extention, and, just as useful, for me, is nightly tester tools, but it cannot, even be installed in SM.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.12) Gecko/20080201 Firefox/2.0.0.12
Postby Lorraine » Tue 04 Mar, 2008 3:59 pm
I wonder if I should try SeaMonkey.
I've been thinking about it for several months, and
I haven't downloaded it yet. I don't think I ever got over
IE 7.0 crash yet.
I don't download anymore....:)
I liked Mozilla suite 6.0 a few yrs ago, but it wasn't compatible
with IE 6.0
-Lorraine
Lorraine
Postby Fulvio » Tue 04 Mar, 2008 7:24 pm
I liked Mozilla suite 6.0 a few yrs ago, but it wasn't compatible with IE 6.0
What do you mean by that? IE and Mozilla are quite different, but, if you must use IE code there is the IE Tab add-on, which can be installed in Seamonkey, and use the IE engine
Considering that you are satisfied with what you have, I would not do a think. It may be painful, after sticking with a very obsolete program, all this time.
Anyway, it was a plwasure to hear from you, after all this time.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9b3) Gecko/2008020514 Firefox/3.0b3
Postby iJohnE » Mon 24 Mar, 2008 5:23 pm
Okay, so I've decided to try SeaMonkey as my default browser on my Vista PC, I was browsing around the Mozilla website searching for the IE-Tab add-on for SeaMonkey, and I can only seem to find it for Firefox 3.
Does anyone know where I can get it?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.0; en-US; rv:1.8.1.12) Gecko/20080201 SeaMonkey/1.1.8
Postby captjlddavis » Mon 24 Mar, 2008 5:59 pm
Try the following for ei_tab 1.3.3:
http://downloads.mozdev.org/ietab/ietab ... indows.xpi
( save link target as........)
or
http://forum.addonsmirror.net/index.php ... entry24795
for ie_tab 1.3.2
HTH
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.9) Gecko/20071030 SeaMonkey/1.1.6
captjlddavis
gold member
gold member
Postby iJohnE » Mon 24 Mar, 2008 6:56 pm
Okay, the next time I have access to a computer I will check out both of the links you provided. :)
UserAgent: Mozilla/4.0 (PSP (PlayStation Portable); 2.00)
Registered users: Google [Bot], MSNbot Media
