Time Synchronizer on PowerMac.
Postby Retired » Tue 18 Mar, 2008 10:58 am
Help me !
I am a retired person and when i stopped working 1996
I got that computer I had used there.
It is a Power Machintosh 7500/100 Powered by Sonnet.
The system is S1-9.0- Mac OS-9.0
I use Netscape Communicator 4,5.
It has worked well until now.
When I now start my Mac there comes up after a while
System failed
Time synchronizer
Type 41
Restart-
When I restart the same occur!
Are there anyone on the Webb who can tell me
What is a Time Synchronizer and how to do to correct my Mac??
I write this on another computer (my wifes-thanks), but
Whant access to the documents I have on my Mac.
I do hope someone on the Web is kind to help me.
Many thanks in advance from
Retired
Living in Landskrona Sweden
e-mail: per.wahlberg@gmail.com
UserAgent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727)
Retired
Postby Antony » Tue 18 Mar, 2008 11:05 am
Hello there,
Welcome to SillyDog701 Message Centre.
You can try to reboot your Mac while holding down the shift key to boot without loading extensions.
Then, (if you can get into Desktop), try dragging the Time Synchronizer out of (Your Mac HD) > System Folder > Extensions
and more it to
Extension (disabled).
Then, you should be able to reboot again normally.
Otherwise,
Try to reset PRAM (depending on your system for the keys).
Hope these help.
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en-US; rv:1.8.1.12) Gecko/20080201 Firefox/2.0.0.12
Registered users: Exabot [Bot], Google [Bot], richard mitnick
