Banner Blind
For discussions and feedback regarding the DJGM.co.uk website.
Moderator: DJGM
Banner Blind
Postby Guest » Fri 21 Feb, 2003 2:42 pm
I am sure that someone has tried Banner Blind, in spite of its present flaws. Some sites look so pitiful after it did its job, that I feel like restoring some sizes. Customization works well. Just right click on the item, which was not removed, select properties, take note of the pixels, and check that size, or add it if not present.
Guest
Re: Banner Blind
Postby Fulvio » Fri 21 Feb, 2003 2:44 pm
Anonymous wrote:I am sure that someone has tried Banner Blind, in spite of its present flaws. Some sites look so pitiful after it did its job, that I feel like restoring some sizes. Customization works well. Just right click on the item, which was not removed, select properties, take note of the pixels, and check that size, or add it if not present.
I am the Guest, if anyone wants to blame me.
Return to DJGM.co.uk
