Mozilla Firefox 3.0.3 released
Postby J-M » Sat 27 Sep, 2008 5:26 pm
This release fixes the Password Manager bug in this week's FF3.0.2:
Firefox 3.0.3 now available for download
Release Notes at
http://www.mozilla.com/en-US/firefox/3. ... easenotes/
New version can be downloaded from
http://www.mozilla.com/en-US/firefox/all.html
[Applied BBCode to shorten link. profman, 10/2/2008]
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X Mach-O; en-US; rv:1.8.1.17) Gecko/20080829 Firefox/2.0.0.17
J-M
Postby Antony » Sat 27 Sep, 2008 8:35 pm
another record breaking update?
UserAgent: Mozilla/5.0 (iPhone; U; CPU iPhone OS 2_1 like Mac OS X; en-us) AppleWebKit/525.18.1 (KHTML, like Gecko) Version/3.1.1 Mobile/5F136 Safari/525.20
Postby edgkenny » Sun 28 Sep, 2008 12:21 am
Antony wrote:another record breaking update?
I had the "losing password" problem with Firefox 3.0.2 which was annoying to me.
The bug seems to be gone so far with the new version.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.3) Gecko/2008092417 Firefox/3.0.3
edgkenny
Postby richard mitnick » Thu 02 Oct, 2008 11:56 am
I am not saying that we should nee Roboform-
BUT-
Even though between FF's Password Manager, some sites' cookies (eg, the New York Times), and the bookmarklet password utility, which I use for MyYahoo!, we *should* have everything we need.
Roboform is not free after ten saved user id's. Being incredibly lazy, I have a zillion. So, I bought Roboform. I do not remember the cost; but whatever I paid has been worth it. I also use it on IE7&8, and I copied the install file and the key to use on a second computer.
SeaMonkey has the best utility for saving any and every user id and password. There is a line in about:config, I think "wallet crypto " something. The default is off; but one can toggle it to on and it will save everything.
>>RSM
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.0; en-US; rv:1.9.0.3) Gecko/2008092417 Firefox/3.0.3 ImageShackToolbar/5.0.0
richard mitnick
FIREFOX 3 UPDATE
Postby MIXXX » Tue 07 Oct, 2008 6:02 pm
Well at least the REAL player record plugin is working now
so this is a good update!!!!!!
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.4) Gecko/20070515 Firefox/2.0.0.4
...Hispanic Causin' Panic...
www.x3dfx.com Voodoo5 5500 still rocking on my legacy machine!!!
MIXXX
Postby richard mitnick » Tue 07 Oct, 2008 6:33 pm
What file types does this RealPlayer plug-in use?
>>RSM
richard mitnick
Postby southernkiwi » Tue 28 Oct, 2008 8:23 pm
On firefox 3.03 and this is the second time it has dumped my passwords. It wont even let me save new ones. At this rate I am hunting for an old version of ff2. none of this rubbish with that version, even IF i am on vista!
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.0; en-GB; rv:1.9.0.3) Gecko/2008092417 Firefox/3.0.3
southernkiwi
Postby Fulvio » Wed 29 Oct, 2008 1:52 pm
Are you telling me that if you go into Tools|Options|Security|Saved Password that you see nothing listed? You know that if you delete cookies that you will not have the passwords available? You will have to start from scratch.
As for not wanting to save passwords, I have never seen a case that I see a request to save a passwords, and I say yes, and the password is not saved. Several sites will not even ask, for sake of security. If you want 2.0.17, try the localized downloads. In your case, you want the English-GB.
I suggest that you do a custom install, in a new folder. Then, you will have to create a new profile. It will be a bit of work to do it right, but you cannot expect that the FF3 profile formats which are different for a number of files, be usable with FF2.x.
I have had absolutely no problem with 3.0.3, and have kept 2.0.0.17, each with a different profile.
Remember that one two updates are likely to occur for 2.x, and will have reach end-of-life by the end of the year.
Postby southernkiwi » Wed 29 Oct, 2008 4:43 pm
thanks for your reply fulvio. Yes, i am saying that all my passwords yesterday had disappeared, and even for sites where it will remember passwords, it wouldn't. I delete cookies regularly but the passwords remain. HOWEVER, today they're all back... definitely not there yesterday, back today and saving as i type. I shall give creating a new profile a whirl.
southernkiwi
Postby Fulvio » Fri 31 Oct, 2008 2:30 pm
I think that the new profile idea is good. There is always something new, and very annoying, happening. If you use a new profile, and it works, make sure that you use that profile.
The profile switch works also for FF.
