Best gaming router available?
Moderators: Edward, Don_HH2K
Postby jwnoodle » Sun 28 Dec, 2008 9:45 am
Mornin-
In process of purchasing a new router, I still play some old school gaming like Counter-Strike. I am looking forward to Starcraft 2 when it comes out, or if it has already. What I want essentially is a router that will provide quality gaming experiences while maximixing my bandwidth. Any suggestions?
Thanks,
Jordan
UserAgent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; InfoPath.2)
jwnoodle
Postby Don_HH2K » Sun 28 Dec, 2008 7:03 pm
Are you looking to use a wired or wireless connection to the router?
My friends and I have had good experiences with Linksys 802.11g hardware, many of us run either the WRT54G or some derivative of it. The newer 802.11n hardware is no exception: we deployed one of these at work over the summer, along with some Linksys-brand 802.11n client hardware, and I can say we had some pretty fast simultaneous transfers going on for both the wired-wireless and wireless-wireless connections.
You probably don't need anything with the VPN layer like that one, but I'd definitely check out the Linksys 802.11n offerings, particularly either the WRT150N or the WRT310N if you're going to be running over Ethernet. They also have a router designed for gaming, though I'd have my doubts that it's that much different from one of the other models.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.0; en-US; rv:1.9.1b3pre) Gecko/20081226 Shiretoko/3.1b3pre
Re: Best gaming router available?
Postby Antony » Thu 08 Jul, 2010 8:19 am
Although I am not a gamer, AirPort Extreme Base Station and Time Capture both work very well for looking up with PS3, Wii and computers.
Make sure you get the one with Gigabit ethernet. If you are getting an router with wireless connection, it would be a good idea to make sure that the router has Bridge mode (most do). If you are connecting wirelessly, I would recommend getting a router that allows manual settings.
Finally, if you are using 802.11 n/g on 2.4 GHz frequency band, you might want to try out a few different channels for the most reliable one.
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.2.6) Gecko/20100625 Firefox/3.6.6
