Netscape 4.79 Question
Postby geffr » Sat 07 Feb, 2009 6:01 pm
Please don't laugh at me, but I'm still using NS 4.79 as my mail client. I just did a fresh install on a new pc. Does anyone remember how to get Communicator (the email program) to start with a blank window rather then accessing aol?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.6) Gecko/2009011913 Firefox/3.0.6
geffr
Postby Fulvio » Sun 08 Feb, 2009 2:55 pm
Aside for the fact that this post should have been in the Communicator newsgroup, check you Preferences|Mail and Newsgroups|Start Mail, or something like it, and uncheck the box.
[profman moves this thread to Communicator Forum. 2/8/2008]
Postby geffr » Mon 09 Feb, 2009 12:27 am
There is no setting like that in 4.7x that I can find. I THINK there is a setting in prefs.js that has to be manually changed, I don't remember, I was hoping someone else would remember. Sorry for posting in the wrong area.
geffr
Postby geffr » Mon 09 Feb, 2009 5:22 am
I feel SO STOOPID! I just saw where Ramona answered this for me last April in another thread.
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
geffr
Postby jjssparkle » Sat 14 Feb, 2009 11:24 pm
and the answer was? ....
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.6) Gecko/2009011913 Firefox/3.0.6 (.NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
jjssparkle
Postby geffr » Sun 15 Feb, 2009 3:11 pm
jjssparkle wrote:and the answer was? ....
From Ramona (14 threads below this),
"To remove that annoying page:
1. CLOSE COMMUNICATOR !!! This procedure will not work otherwise ...
2. Use the Windows Explorer file manager and go to your ~\Netscape\Users\{username}\ directory.
3. Find the file named prefs.js and make a backup copy. You can do this quickly in Windows Explorer by right-clicking prefs.js, choosing Copy, then right-click, select a folder for the backup copy, and choose Paste.
4. Use Notepad or another text editor to open prefs.js.
5. Add the following line on a line of its own:
user_pref("mailnews.start_page.enabled", false);
You may wish to copy and paste the above line to avoid misspelling or a typo.
6. If you typed in the above line, verify that it is exactly as shown above. Errors will cause this to fail to work, and may result in a corrupted prefs.js file.
7. Close the text editor and save changes.
8. Restart Netscape."
geffr
Return to Communicator
Registered users: Google [Bot], James
