Router advice
Moderators: Edward, Don_HH2K
Router advice
Postby James » Tue 07 Apr, 2009 11:00 am
I'd like to get a new wireless router and set up a home network. Here are my priorities:
- security
- speed (not a gamer but I want reasonable bandwidth)
- ease of set-up
Suggestions?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.0; en-US; rv:1.9.0.8) Gecko/2009032609 Firefox/3.0.8 (.NET CLR 3.5.30729)
Postby Don_HH2K » Tue 07 Apr, 2009 4:25 pm
You may want to take a look at the Linksys WRT series. The WRT platform is stable and solid, and are ready to go right out of the box, though of course you'll want to set up encryption on your network later.
If speed is a concern, remember that your connection out to the Internet is probably slower than 802.11b (11mbps though realistically lower), so you'll almost certainly have your Internet connection speed covered by an 802.11g router like the Linksys WRT54G. The WRT54G has five-star reviews all over the place, so I probably don't need to go over the specifics when plenty of other people have gone over them in more comprehensive detail.
If you're looking to make fast transfers from PC to PC on your network, you might want to look into an 802.11n router like the Linksys WRT160N. 802.11g will realistically get you somewhere between 24mbps and 48mbps depending on signal strength, whereas 802.11n delivers faster speeds over greater distances of up to 600mbps - typically you'll get somewhere between 100mbps and 300mbps, depending on how many channels a given .11n device uses. 802.11n is a relatively new technology, but it's also backwards-compatible with 802.11g, so you can buy an 802.11n router for the future and still be able to use 802.11g equipment with it. You can also upgrade to the WRT310N for gigabit Ethernet, if you want to wire a gigabit-enabled PC directly to the router (instead of using Wi-Fi), though this is probably overkill for your purposes.
As far as security goes, the software that runs on both the WRT54G and the WRT160N supports WPA2 data encryption, which at the moment is the best you can get without going proprietary. Both routers support a mixed WPA/WPA2 mode in the event that one or more of your PCs don't support WPA2. In all cases I would recommend against using WEP to do data encryption.
Like I said before, both routers I mentioned are ready to go out of the box. It looks like you're running Vista, which will let you set up a home network inside the Network and Sharing Center.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.0 x64; en-US; rv:1.9.2a1pre) Gecko/20090404 Minefield/3.6a1pre (.NET CLR 3.5.30729)
Re: Router advice
Postby Antony » Wed 08 Apr, 2009 5:23 am
James wrote:I'd like to get a new wireless router and set up a home network. Here are my priorities:
- security
- ease of set-up
Suggestions?
Three choices: AirPort Extreme Base Station, Time Capsule and AirPort Express Base Station
I have previous generation of both AirPort Extreme Base Station and Time Capsules. (And had a previous generation of AirPort Express Base Station). They are all very easy to set up, and provides great compatibility with PC, Mac, PS3, Wii etc. All those devices are easy to set up (under both Mac and Windows), and offer great security support.
I highly recommend getting a device that supports 802.11n (draft), even if your current PCs aren't 802.11n equit. Once you tried 802.11n speed, you don't even want to go back to 802.11g. A high speed wireless home networking is important, and it should not be limited by the speed of internet, there are other needs for fast home wireless networking such as file transferring, music/video streaming etc.
The current generation of AirPort Extreme Base Station and Time Capsule offer simultaneous dual-band on both the 2.4GHz and 5GHz bands, allowing all the devices on the network to use the most efficient band automatically.
The new guest networking on current generation of AirPort Extreme and Time Capsule allows users to set up a separate Wi-Fi network with a separate password for visitors. A great way to give your guest access to internet and keeping your home network secure. Please see [sdt=15552]this thread[/sdt]
That's my two cents.
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.5; en-US; rv:1.9.0.8) Gecko/2009032608 Firefox/3.0.8
Postby James » Wed 08 Apr, 2009 6:48 pm
Thanks so much for the advice, guys. :)
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.8) Gecko/2009032609 Firefox/3.0.8
Postby Edward » Fri 10 Apr, 2009 6:28 pm
I have a Linksys WRT54G here, bought it a year and a half ago. No problems to report and it works great with wireless, very secure as well.
UserAgent: Mozilla/5.0 (X11; U; Linux i586; en-US; rv:1.8.1.21) Gecko/20090402 SeaMonkey/1.1.16
Postby James » Fri 10 Apr, 2009 10:46 pm
Hi Edward
It's the one I'm now using. Thanks.
Registered users: Exabot [Bot], MSNbot Media, Yahoo [Bot]
