"Is there a pattern of repetition? That is, always the same letter(s)/word(s)/section(s) on a given page, every time you bring up that page? How big are the blobs? On Google maps, I see a 'perspective' (at an angle) shadow of the descriptive 'balloon', the shadow is 'south-east' of the balloon. And the shadow of the push-pin is 'north-east', extending from the pin point. Does this match what you are seeing?
What type of display do you have: LCD, CRT, ??? How old is the display? Do you have any problem with the text in any other program"
Two patterns -- underneath type on some web pages and on maps. The google issue is somewhat confusing as I know there is meant to be a shadow -- but it's off in that it's jagged and looks like a mistake as opposed to a shadow. So best not to use that example.
I've copied it to paint in the past and just did it again to check -- looks exactly as it does on the web page.
There is an intuitive part of me that says this is the video card -- ATI -- but fiddling with that hasn't helped either...checked for updates, reinstalled it, etc.
Are you by any chance a Facebook member? I could create a group and post the pix and send you the link....
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; .NET CLR 1.0.3705; Media Center PC 4.0; .NET CLR 2.0.50727; .NET CLR 1.1.4322)
