Internet Connection Sharing problem when installing...
Moderators: Edward, Don_HH2K
Postby Paradox » Wed 15 Apr, 2009 9:02 am
Hi all.
I'm not sure if this is the right section or not but I thought I would post here anyway. I'm trying to install a program, more specifcally, the Nintendo Wifi USB adapter. When I install it, I get an error that says "Internet Connection Sharing Error." I've figured out that the solution may be to turn off the ICS for the connection I use but after I turn it off and start the installer, the ICS gets turned back on and I keep getting the error. Is there some way to fix this?
UserAgent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 2.0.50727; .NET CLR 3.0.04506.648; .NET CLR 3.5.21022; MSN Optimized;CA; InfoPath.1; MSN Optimized;CA)
Paradox
Postby PaulD » Wed 15 Apr, 2009 8:37 pm
Have you been to the Nintendo site yet for help?
A Google search of [ nintendo wifi usb connector troubleshooting ] gives over 20,000 hits. The first one is this. One link there ("Using ... ") is this.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.8) Gecko/2009032609 Firefox/3.0.8
Postby Antony » Thu 16 Apr, 2009 1:49 am
Is that for Nintendo Wii or for Nintendo DS?
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.5; en-US; rv:1.9.0.8) Gecko/2009032608 Firefox/3.0.8
Postby Paradox » Fri 17 Apr, 2009 8:49 pm
PaulD wrote:Have you been to the Nintendo site yet for help?
I've tried that before and I haven't been able to find the solution. I've looked through the links, including downloading a registry tool that's on the site but it didn't work.
Antony wrote:Is that for Nintendo Wii or for Nintendo DS?
It's for the DS though I believe you can also use it to access Wifi through the Wii.
UserAgent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; GTB5; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30)
Paradox
Postby Antony » Fri 17 Apr, 2009 9:06 pm
Paradox wrote:It's for the DS though I believe you can also use it to access Wifi through the Wii.
Okay. I only have a Wii. The WiFi connection is built-in.
Registered users: Exabot [Bot], Google [Bot], Yahoo [Bot]
