flash player problems
Postby san » Sat 27 Jun, 2009 6:46 pm
can anyone help or give me some advice im having real problems installing flash player and iv tried everything and nowt is working and its doing my head in big time i install it but it doesnt show that it has also what is the best browser please help before i hit this thing with a hammer thanks
Edit: split from [sdt=14719]Flash Player 10 (beta)[/sdt] by Don_HH2K
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.7pre) Gecko/20070815 Firefox/2.0.0.6 Navigator/9.0b3
san
Postby Don_HH2K » Sat 27 Jun, 2009 7:27 pm
It would be helpful if you could give us as much of the following information as you are able:
  1. What operating system you are running (e.g. Windows XP, Windows Vista, Mac OS X Leopard, etc.)
  2. What browser you are attempting to install Flash for (e.g. Internet Explorer 7, Netscape Navigator 9, etc.)
  3. Where you downloaded the Flash installer from
Your best bet is to use Adobe.com's download page, which can automatically detect most of this information, and direct you to the appropriate installer package.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.1 x64; en-US; rv:1.9.2a1pre) Gecko/20090603 Minefield/3.6a1pre (.NET CLR 3.5.30729)
Postby san » Sat 27 Jun, 2009 8:00 pm
hi im on xp iv tried a couple of browsers firefox internet explorer 8 and netscape i downloaded from adobe.com it downloads but doesnt show as being installed properly im fed up and my head is done in big time thanks for your reply best wishes san x
UserAgent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322)
san
Postby Don_HH2K » Sat 27 Jun, 2009 8:08 pm
If you launch Netscape and type "about:plugins" (without the quotes) into the address bar where you usually type a Web address, does the resulting page mention Flash anywhere?
In Internet Explorer 8, go to Tools and then click Manage Add-ons. Towards the lower-left, there will be a drop-down menu labeled "Show"; from it, choose "All Add-ons". Does "Shockwave Flash Object" show up anywhere in that list?
Postby san » Sat 27 Jun, 2009 8:24 pm
just had a look on internet explorer and Shockwave Flash Object is not there
san
