What Is The Name Of The Saved Forms/Password File In FF 3.x?
Postby geffr » Mon 20 Jul, 2009 5:08 pm
i suspect this has been posted before but i had no luck with search. Installed 3.5.1 portable to a new folder & then copied my 3.0.11 profile in 3.5. Everything worked except saved passwords.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.1) Gecko/20090715 Firefox/3.5.1 (.NET CLR 3.5.30729)
geffr
Postby Fulvio » Tue 21 Jul, 2009 12:40 pm
There was no need to copy the profile used from one version for another, because each version will write into the profile, as needed. I replaced my 3.0.11 with 3.5.1 portable, just yesterday, but did nothing to the Profile, which is in this path, on my computer: C:\FFportable\FirefoxPortable\Data\profile (also in my thumb drive).
I have all the passwords. My profile has both signons3.txt, and signons.sqlite, as well as key3.db file. FF portable is in my hard drive, mainly, as a check for possible issues.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.22) Gecko/20090605 SeaMonkey/1.1.17
Postby geffr » Tue 21 Jul, 2009 12:49 pm
I discovered the answer, in case anyone else runs into this. I wanted to have both versions, in case 3.5 was buggy for me, so i copied the profile; but I have since learned that a significant amount of people are also experiencing this even if they install over the top of an old version. If you experience this, the solution that worked for me is to shut down FF, delete signons.sqlite, & restart; passwords are once again available.
geffr
