Parallels Desktop 4.0.3846 released
Postby Antony » Thu 03 Sep, 2009 1:27 am
Parallels, Inc. has released a maintenance update Parallels Desktop 4.0 for Mac last week, making the version to build 4.0.3846.
Build 4.0.3846 contains only bugfixes and improvements over previous update (build 4.0.3844), in particular, the support for Windows 7 has been improved in many aspects.
Bugfixes and improvements in Parallels Desktop 4.0 Update (build 4.0.3844)
- Support for creating virtual machines with Mac OS X Leopard Server and Snow Leopard Server on Nehalem-based Mac Pros and Xserves – added.
- Support for creating Boot Camp virtual machines with Windows Vista SP2 – added.
- Support for creating Boot Camp virtual machines with Windows 7 – added.
- Support for running Windows 7 in virtual machines – improved.
- Windows 7 system tray icons – improved.
- Express installation of Windows 7 – added.
- Shared profile issues in Windows 7 – fixed.
- Direct printing feature in Windows 7 - fixed.
- Sound card support in Windows 7- fixed.
- Other Windows 7 improvements and bugfixes.
- Support for running Mac OS X Snow Leopard Server in virtual machines - fixed.
- Problems with installing Parallels Tools in the Ubuntu Linux 9.04 guest OS - fixed.
- Support for using Mac OS X Snow Leopard (including the 64-bit version) on host computers – improved.
- A number of bugs for using Parallels Desktop and running virtual machines on host computers with Mac OS X Snow Leopard fixed. Most important bugs are listed below:
* QuickLook plug-in crashes when trying to preview the contents of a PVM bundle (the crash is invisible for the user).
* The update may fail to install the downloaded updates for Parallels Desktop 4.0.
* Parallels Mounter and Explorer may fail to open Parallels Desktop disk images.
* It may be impossible to connect to the virtual machine from the iPhone client.
* Creating a virtual machine snapshot may take a very long time.
* Opening a web link from inside a Windows-based virtual machine in Mac Safari
using the Shared Internet Applications feature may result in appending garbage
to the link.
* On 64-bit host computers, connecting a USB device to a virtual machine may cause a kernel panic.
These and a number of other bugs have been fixed in Parallels Desktop 4.0 Update (build 4.0.3846).
Parallels Desktop 4 for Mac is a virtualization solution that enables users to create virtual machines on any Macintosh computer with an Intel processor (1.66 GHz or faster). Users can install a Windows, Linux, or other operating system in each of their virtual machines, and work with them and their applications side-by-side with their Mac OS X applications.
Parallels Desktop 4 for Mac supports many 32-bit and 64-bit Operating Systems (for 64-bit operating systems in virtual machines, an Intel Core 2 or higher processor is required), DirectX 9.0 wiht Shaders Model 2, SSE4 support, Apple remote disk, experimental support of Windows 7, and iPhone integration (controlling virtual machines from an iPhone using Parallels Mobile app).
You can save $5 on Parallels Desktop for Mac by simply using our exclusive discount link. (Detail is available on this previous report.)
Our exclusive discount link:
Special offer! Buy Parallels Desktop 4.0 for Mac with $5 discount
If you have multiple Mac, you can save more by getting a Parallels Desktop 4.0 for Mac Family Pack, which comes with 3 licenses for only $199.99, a saving of $40.
Parallels Desktop 4 for Mac requires a Macintosh computer with an Intel processor (1.66GHz or greater). To run 64-bit operating systems in virtual machines, an Intel Core 2 or higher processor is required.
Minnimum 1GB of RAM, 2GB of RAM is recommended. About 15GB of disk space for each virtual machine.
Mac OS X Leopard v10.5.2 or later, or Mac OS X Tiger v10.4.11 or later.
UserAgent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.2) Gecko/20090729 Firefox/3.5.2
Registered users: No registered users
