Thunderbird
Thunderbird
Postby gdrapeau » Wed 18 Nov, 2009 11:44 am
Hi,I run Winxp, FireFox 3.5.5 is my default Browser, Thunderbird 2.0.0.23 is my default mail program.I noticed FireFox is showing in (Control Panel add & remove programs set programs access & defaults )and Thunderbird is not showing at all. I want to know why?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.5) Gecko/20091102 Firefox/3.5.5
gdrapeau
Postby Fulvio » Wed 18 Nov, 2009 2:52 pm
If Thunderbird has been, properly, installed, it should show up in the Add/Remove, right below Mozilla Firefox, as Mozilla Thunderbird. Can you find the installed folder in this path:
C:\Program Files\Mozilla Thunderbird ?
In my experience, the program may not show up if the Portable version is installed on the hard drive, or you work out of an unzipped file, rather than an installer file.
I don't believe that the profile matters, but if all is working fine, I would leave it alone, or install the program on top of the existing one.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.15) Gecko/2009101601 Firefox/3.0.15
Postby PaulD » Thu 19 Nov, 2009 12:54 am
"set programs access & defaults"
Postby Fulvio » Fri 20 Nov, 2009 1:00 pm
PaulD wrote:"set programs access & defaults"
Paul, may be I did not understand the original question, but our friend said:
There are some programs which are not in the Control Panel|Add/Remove, and I had to go to the Program File folder, and find an Uninstall folder to get rid of it. I think that he means that Thunderbird is not listed, even, in the Add/Remove.[/quote]
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US) AppleWebKit/531.21.8 (KHTML, like Gecko) Version/4.0.4 Safari/531.21.10
Postby PaulD » Fri 20 Nov, 2009 7:04 pm
Here is how I parsed / punctuated the statement part of the post:
(Control Panel --> add & remove programs --> set programs access & defaults )
I understand the anomaly to be that FF does show in SPAD, and TB does not appear.
Question for gdrapeau:
At which of the SPAD sections are you looking? You'll need to put a check mark in the "Custom" section, and then use the pull-down arrows at the right end of that bar.
Does Thuderbird not show up here at all?
Registered users: Google [Bot], MSNbot Media
