Odd Loading Problelm with Firefox 3.5
Postby humpd » Mon 23 Nov, 2009 8:56 pm
I had a boot up problem with my computer earlier tonight in which, during the boot up process, the computer was inadvertently turned off. Windows 7 went through a repair which seemed to work just fine. However, now when I use Firefox, while the program is loading, I get the following message:
"Firefox could not install this item because "install.rdf" (provided by the item) is not well-formed or does not exist. Please contact the author about this problem."
I have uninstalled FF but the problem persists. I can run and use FF as you can see but I get this error message each time I try to boot it up. This problem did not exist until after the computer turn on/turn off fiasco. Any idea about what I should do? I thought about using system restore but it wants to go back to the point earlier this month when I installed ITunes and I do not want to have to uninstall and reinstall that program again. If that is the only option, I will do it but any other ideas regarding a fix?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.1; en-US; rv:1.9.1.5) Gecko/20091102 Firefox/3.5.5 (.NET CLR 3.5.30729)
humpd
Postby iJohnE » Mon 23 Nov, 2009 10:01 pm
Do you get this problem when running in safe-mode?
How about creating a test profile and see if you still get the same problem.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.0; en-US; rv:1.9.1.5) Gecko/20091102 Firefox/3.5.5
Laptop: Dell Vostro 3750: Intel Core i3 @ 2.30Ghz, 6GB DDR3 RAM, 250GB HDD, Intel Integrated Graphics, Windows 7 Ultimate.
Postby humpd » Mon 23 Nov, 2009 10:27 pm
I have not tried to launch in safe mode and I will create a new profile and see if it happens again. It has the same problem with my wife's profile in addition to mine.
humpd
Postby humpd » Mon 23 Nov, 2009 10:29 pm
I just tried a test profile and the same thing happens. I'll try a safe mode launch tomorrow.
humpd
Postby humpd » Mon 23 Nov, 2009 10:37 pm
I just disabled my NoScripts Add On and it seems the problem no longer exists. I will close and launch a few more times to see if this is the problem.
humpd
Postby iJohnE » Tue 24 Nov, 2009 6:22 am
If it is NoScript, try uninstalling it and then reinstalling the updated version from the Mozilla Addons site.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 6.0; en-US; rv:1.9.1.4) Gecko/20091017 SeaMonkey/2.0
Postby humpd » Tue 24 Nov, 2009 8:42 am
That is the plan. I think it will work because I had an issue with NoScript before and that process worked. Thanks for the tip.
humpd
Postby iJohnE » Tue 24 Nov, 2009 2:48 pm
Welcome. Always glad to help when I can. It makes me feel important. :)
