As always any help will be appreciated.
brad4221 wrote:When composing I click on addresses and by default pops up "Collected Addresses). I don't want that so I arrow to one of the private accounts I had imported from 4.7 and Outlook. How do I set one of these as default and/or delete the "collected addresses) from my computer?
I'm on XP so by profile directory you mean "setting folder" right? I can get there and I can open pref files but there has to be a line some where that I can set the default to "pab" and not "collected address". Ya think?
brad4221 wrote:Thanks for your help. While composing a letter I cllick on addresses I get the address book window with "Look in - collected addresses" Since I don't use or save collected address, then I must use arrow to get the full list:
"Collected Addresses"
"pab" (Not "Personal Address Book" but "pab"
"Outlook Express Address Book"
This is the process I recently did on my w95 / N7preview and it worked fine. Although I did not have the "pab" files, I had abook.mab in files and only had a empty "collected addresses" in my email view's. When deleting abook.mab, all addresses moved into "collected" and Netscape buildt a new "Personnel Address" folder. I then copied/pasted them into "Personnel Address Book". Everything works fine.captjlddavis wrote:You should have several .mab files.
Do you have an abook.mab file?
If yes, delete the abook.mab file and then open NS.
On the main menu,(accross the top) select Window ->Address Book
in left pane you should have:
Collected Addresses
pab
Personal Address Book should be empty.
Please verify if this is true and post back and we will try and continue in this direction.
regards:
Brad, if you did Mr.Davis's suggestions (with Netscape closed) which is the SAME thing I did (see my post, and Update Notice.. "renamed not deleted abook.mab") I don't know if doing it again is going to help. I was coming out of a "rename" profile situation that caused the "Personnel Address Book" to disappear. The abook.mab was still in file and text view appeared to be good. Mr. Davis's suggestion was the technique I used to have Netscape rebuild and provide a new "Personnel Address Book" back to the top of the list. Maybe / could be, you did not have Netscape closed, including Quick Launch closed (if active) when you deleted abook.mab?brad4221 Posting Time: 25 Apr, 2003 6:43 pm wrote:Again, thank you all for your valued imput. I've tried Mr. Davis's directions down to the line. No change.
Fulvio had a suggest that I tried. I was at Modern theme but I change to another and then back and no difference.
I'm still at Collected Addresses on the first line (default)
Then "pab"
In "Window - Address Book" I thought I could drag pab up and replace Col. Add. but NO. I've tried right clicking....nothing.
Does this sound like a reinstall might be the answer. I'll wait your reply.
| [SillyDog701 home] [Netscape] [download NS] [MozInfo701] [MacCentre701] [Feedback] [Search] [Sitemap] All messages posted in this forum do not necessarily represent SillyDog701. This forum is operated by Antony Shen. All rights reserved. Copyright Notice. Privacy Statement. |
