Adding to Context Menu
Postby brendandonhu » Sun 27 Apr, 2003 6:20 pm
Hi, im new here :D
Please know this is NOT an advertisement for the message board I am refering to :roll:
I made some javascripts for another message board so you can right click a link to a thread on the board and go straight to the reply page, print it, etc. But its IE only and a netscape user asked if I could make it work in netscape. I think the javascripts would work in netscape if I could add them to the right-click menus.
If you want to look at my javascripts there is a more info at this thread
http://forums.techguy.org/t130582/s.html
The important part of the script is this
var x = (external.menuArguments.event.srcElement.href);
Which gets the URL that the link is pointing to. Anyone know if that will work in Netscape and how to add it to the right-click menus?
Thanks in advance![/code]
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows 98)
brendandonhu
Re: Adding to Context Menu
Postby Antony » Sun 27 Apr, 2003 9:56 pm
brendandonhu wrote:...
Thanks in advance!
Hello Brendandonhu,
To be honest, I don't usually work with IE-only codes. In fact there are still quite a lot of NS-only features as being used in SillyDog701.
If I have time, I will check the detail to see if I can help.
The best approach... (which will cost you $105 AUD, cheaper in USD)
Buy Danny Goodman's JavaScript Bible either the Gold Edition (hard cover, more chapters) or 4th Edition (paper back).
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.0.2) Gecko/20030208 Netscape/7.02 (CK-SillyDog)
Postby brendandonhu » Sun 27 Apr, 2003 10:07 pm
Thanks for your reply.
I will look at that book, I am interested in it anyway as a beginning JS writer.
Are you saying that code is IE only though?
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows 98; Win 9x 4.90; Hotbar 4.2.4.0)
brendandonhu
Postby Antony » Sun 27 Apr, 2003 10:10 pm
Not sure, But since you mentioned that works for IE (only), I assumed it.
I am at work now. The JS Bible is at home.
Postby brendandonhu » Sun 27 Apr, 2003 10:19 pm
Thanks, the reason it currently only works in IE is because I only knew how to add it to the right click menu in IE, which is done thru the registry.
brendandonhu
Postby Antony » Sun 27 Apr, 2003 10:32 pm
your post from another forum wrote:Heres my modifications on Mosaic1's Quick Reply for TSG.
Sorry, What is TSG by the way?
(Can't test your zip in this computer, sorry.)
Postby brendandonhu » Mon 28 Apr, 2003 6:01 am
TSG is tech support guy, which is the msg board I made it for.
And mosaic1 is the user that originally did it.
brendandonhu
Registered users: Google [Bot], Google Feedfetcher, Yahoo [Bot]
