by Fulvio » Tue 20 May, 2003 10:00 pm
Melissa wrote:I'm not sure but I believe my computer has a virus or something. I'm hoping if someone could help me.
This is my problem. My computer is painfully slow and I can't seem to get into hotmail to check email or amazon to look at my account. It's somehow blocking these sites - I don't have cookies blocked either. I have scanned my harddrive for viruses. Can anyone help me? Any suggestions? I have also used Spybot and Adaware too.
Regards
Melissa,
DJGM is quite correct. This is more of a Windows question, and should be moved there.
But, since you are still around, I would say, that you could have not had a problem all along. Is it getting worse or just bad all the time. Since you use IE, and I don't, is there something similar to the Netscape Cache which can clog up your system? There is Cache or Temp.Internet File which have to be flushed or else the computer will come to a grinding halt. We had this problem four years ago, knowing very little, and never doing any housekeeping. Our computer just about stopped doing anything , using AOL, which is patterned after IE. Delete that stuff, and I would expect better performance. My apologies if I selected something too obvious.
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.0.2) Gecko/20030208 Netscape/7.02 (Compact - Build 2)
