Netscape 7.1 User Reports/Feedbacks
Postby Edward » Tue 01 Jul, 2003 7:40 pm
Windows version: After three launches, the Bookmarks finally appeared in the Sidebar! It also took close to 20 minutes to install this under Windows, and this is on a K-6 2/500 MHz system with 1/2 Gb of RAM!
Linux version: Just like version 7.02, which was the first Linux version of Netscape I used, the footers do not print. Installation time under Linux: less than 2 minutes on a Pentium-MMX/166.
Postby Gregor » Wed 02 Jul, 2003 2:31 am
In final build the SkyPilot theme is now working (version 1.9i). I noticed interesting behaviour regardind webmail:
After logging in Netscape says, that can not connect to imap.mail.netcenter.com . But, just after two seconds when you press on the Inbox folder all mail is there and everything is normal.
"We don't receive wisdom; we must discover it for ourselves after a journey that no one can take us or spare us." Marcel Proust.
Gregor
Postby Edward » Wed 02 Jul, 2003 6:03 pm
An interesting twist...
Linux version:
When printing a page in Landscape mode, the footers print, but the headers do not.
It would be nice if printing were bug-tested before releasing. :(
UserAgent: Mozilla/5.0 (X11; U; Linux i586; en-US; rv:1.4) Gecko/20030624 Netscape/7.1
Postby samuelp » Wed 09 Jul, 2003 12:14 pm
I have installed Netscape 7.1 on a Linux box.
No problem at all except I can't use the Java Plugin (gcc problem and another problem with an old Java plugin)
No improvement concerning the delay to start Netscape 7.1 in comparison of Netscape 7.02, but the browser seems to be more responsive.
Some bugs were fixed.
UserAgent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.4) Gecko/20030624 Netscape/7.1
samuelp
Postby Mandrake » Wed 09 Jul, 2003 8:18 pm
Windows Me - no problems at all, runs faster than 7.0.x
Windows XP Profesional - same improvements as those noticed in Windows Me
Linux - loading speed similar to that of 7.0.x, but once Navigator was loaded it was more responsive than 7.0.x
Postby Edward » Mon 14 Jul, 2003 5:31 pm
Update:
Linux version - Forget it. Could not use it, profiles kept corrupting, plus Print Preview does not exit back to the Navigator window correctly. Tested on two different systems, same results. :(
Windows version {Win 98} - The new "glassy" N throbber in the Classic theme, is pixelated, noticable around the outer edge of the throbber, all the way up to 1280x1024 resolution. Scrolling still does not work, even with the latest Logitech software. :shock:
To say I am "disappointed" would be putting it rather mildly.
Improved in Netscape 7.1
Postby Antony » Mon 28 Jul, 2003 12:59 am
Improved in Netscape 7.1 (over 7.0x)...
The Mail Notification will work even without email window open. (After first checking of email.)
Postby jksteinhauer » Mon 28 Jul, 2003 10:04 pm
A welcome improvement.
jksteinhauer
Postby Antony » Thu 31 Jul, 2003 3:39 am
Not sure if this is just me,
Secured connection (SSL), aka https connections, are extremely slow with Netscape 7.1. Sometimes too slow to work. (I have problem paying my bills over NS 7.1, but no problem with IE6 which of course was not my first choice.)
Netscape 7.02 did not experience such problem.
Anyone use secured connection often?
Postby vipergg » Thu 04 Sep, 2003 7:35 pm
Anyone seeing any problem with the browser hanging when you open the mail client while the browser is open ? I'm seeing this on ME and never saw any problem with version 7.02 . Any known fixes ?
UserAgent: Mozilla/5.0 (Windows; U; Win 9x 4.90; en-US; rv:1.4) Gecko/20030624 Netscape/7.1 (ax) (CK-SillyDog)
vipergg
Postby RootsMan » Sat 27 Sep, 2003 7:49 am
Greetings,
I upgraded from Netscape 7.01 Streamline to Netscape 7.1 Streamline last night (Fri. 9/27/2003).
So far so good... :)
My profile/settings, email, bookmarks, address book are all accessible.
Glad to have the spam filter.
Did not notice any slowdown using Secure Socket Layer (SSL).
Browser and email client are working well together.
RootsMan
Postby Antony » Tue 30 Sep, 2003 8:52 am
DJGM wrote:On closer inspection, it seems that this unofficial test build of Netscape 7.1
actually bundles Sun Java 2 v1.4.0_02, so it's not quite as up to date as I
originally stated.
The Sun Java 2 included in Netscape 7.1 (official release build) has following interesting things.
The Java component is actually called "jre140_02i.exe", zipped into "jre140_02i.zip"
However, it has following references...
Registry Key=/Sun/Java 2
Version=1.4.1_02
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en-us) AppleWebKit/85.7 (KHTML, like Gecko) Safari/85.5
Postby DJGM » Tue 30 Sep, 2003 11:24 am
IMHO, Netscape 7.1, as good a browser suite as it is, was a bit rushed. Aside from the fact that
the (now unemployed or re-assigned) Netscape employees on the AOL payroll, wanted to get
a new Netscape release out the door, before AOL locked the door and threw away the key, I
think what is now available to download as Netscape 7.1 was originally intended (by the
now former Netscape developers) to be Netscape 7.1 Preview Release 1.
If you download the online installer of Netscape 7.1, and use it to download your own choice of
components, have a look at the "config.ini" file. There are a number of references to "7.1b1",
minus the quotes which is what would've been added to the end of the useragent string, to
denote that it's a preview release (or beta version). Since the decision had more than likely
already been made by AOL, to kill off the Netscape browser, the Netscape devs didn't want
to make it immediately obvious that v7.1, the last ever major Netscape release, was in fact
a beta version, so the UA string was appended with "Netscape/7.1" to make it appear to be
a "gold" release, as opposed to "Netscape/7.1b1", had it been released as a preview release.
Had AOL not decided to disband the Netscape browser division when they did (or at the very
least delayed the cancellation of all future Netscape browser development, until the end of
the year) the actual full release of Netscape 7.1 may have been built upon Mozilla 1.4.1.
That way, Netscape 7.1 (final) wouldn't have had the serious GDI resource leak issue on
machines running Windows 98, and perhaps the Print Preview feature wouldn't have
caused so many problems with the Linux version of the browser suite.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X Mach-O; en-US; rv:1.4) Gecko/20030624
Postby Fulvio » Wed 26 Nov, 2003 3:33 pm
DJGM wrote:IMHO, Netscape 7.1, as good a browser suite as it is, was a bit rushed. I
think what is now available to download as Netscape 7.1 was originally intended to be Netscape 7.1 Preview Release 1.
If you download the online installer of Netscape 7.1, and use it to download your own choice of components, have a look at the "config.ini" file. There are a number of references to "7.1b1",minus the quotes which is what would've been added to the end of the useragent string, to
The actual full release of Netscape 7.1 may have been built upon Mozilla 1.4.1.
That way, Netscape 7.1 (final) wouldn't have had the serious GDI resource leak issue on machines running Windows 98, and perhaps the Print Preview feature wouldn't have caused so many problems with the Linux version of the browser suite.
I was curious how the e-mail would look like minus the obligatory anti-AOL rants. I quoted the revised version.
I know that this is something which has bothered a lot of people, but it is hard to make any sense out of an otherwise useful message, rants included. I got the the message, and I am with you, but please use some restraint.
Postby Wellander » Wed 26 Nov, 2003 4:22 pm
DJGM wrote:IMHO, Netscape 7.1, as good a browser suite as it is, was a bit rushed. Aside from the fact that
I have noticed thaqt too but thought nothing of it.
UserAgent: Mozilla/4.0 (compatible; MSIE 5.5; Windows NT 5.0; .NET CLR 1.1.4322)
Wellander
Return to Reference Centre
