A solution for NE 7.01's Skyoilot skin
Postby iansfan » Wed 16 Jul, 2003 5:19 pm
SOLUTION TO SKYPILOT'S SKIN IN NE7.01
I downloaded NE 7.01(from Mozdev Themes) and lost the Skypilot skin. Here's what I did to get it back, hope it works with others:
1.Download Skypilot skin again.
2. Click ok to change the skin, any way.
3. When you get message that is not compatible with your NE version, click ok and ingore this pop add.
4. Shot down your PC
5.Restart it again.
6. Open your NE 7.01 browser, your Skypilot skin should hopefuly appear. It did on my computer. I use Windows XP 2000.
Good Luck!
Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.4) Gecko/20030624 Netscape/7.1 (ax)
:D
iansfan
Re: A solution for NE 7.01's Skyoilot skin
Postby Fulvio » Thu 17 Jul, 2003 12:06 am
iansfan wrote:SOLUTION TO SKYPILOT'S SKIN IN NE7.01
5.Restart it again.
Good Luck!
:D
You are using 7.1. Do you mean 7.01 or 7.1. They are different and they require different versions of Skypilot. The decimal points count!
Re: A solution for NE 7.01's Skyoilot skin/followup
Postby Fulvio » Thu 17 Jul, 2003 12:19 am
I tried to get it. And, although everything went smoothly, I could not find the skin in View|Apply themes. I restarted Netscape, with no idea of what was wrong since all the files were present. Then, I checked again, and lo and behold, Skypilot appeared out of the blue sky! (Pun intended) in the list.
Then, I restarted Netscape again, and all was well.
I had no problem with 7.01, but I am not sure if the version is correct for it.
You may have skypilot in the list, and don't know it.
Postby Mandrake » Thu 17 Jul, 2003 12:46 am
Why all this improvisation? Just download and install the Mozilla 1.4 Skypilot theme . . . since Netscape 7.1 IS based Moz 1.4 . . . if it's Netscape 7.01, then that is a totally different story.
Postby Gregor » Thu 17 Jul, 2003 2:58 am
Mandrake wrote:Why all this improvisation? Just download and install the Mozilla 1.4 Skypilot theme . . . since Netscape 7.1 IS based Moz 1.4 . . . if it's Netscape 7.01, then that is a totally different story.
You are absolutelly right. I have some difficulties back then (posted in User feedback topic). Then I used the mentioned/updated theme for Moz 1.4 and it is working without any problems since. It has a little bit smaller buttons in navigation bar, all the rest is the same . Version 1.9i.
"We don't receive wisdom; we must discover it for ourselves after a journey that no one can take us or spare us." Marcel Proust.
Gregor
Postby Fulvio » Thu 17 Jul, 2003 10:39 am
I have no idea what he was talking about. But, he mentions 7.01, while posting with 7.1. I went to mozdev.org, and it shows that 1.9i is ok for NS7.1.
However, I had to restart Netscape twice to get it.
Re: A solution for NE 7.1's Skyoilot skin
Postby iansfan » Thu 17 Jul, 2003 1:02 pm
I downloaded NE 7.1(from Mozdev Themes) and lost the Skypilot skin. Here's what I did to get it back, hope it works with others:
5.Restart it again.
6. Open your NE 7.1 browser, your Skypilot skin should hopefuly appear. It did on my computer. I use Windows XP 2000.
Good Luck!
:D
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; Q312461; YComp 5.0.2.6; Hotbar 4.2.6.0)
iansfan
Re: A solution for NE 7.1's Skyoilot skin(NE7.1)
Postby iansfan » Thu 17 Jul, 2003 1:03 pm
5.Restart it again.
Good Luck!
:D
I MEAN NE 7.1, SORRY
iansfan
Postby iansfan » Thu 17 Jul, 2003 1:06 pm
Fulvio wrote:
iansfan wrote:SOLUTION TO SKYPILOT'S SKIN IN NE7.1. tHIS IS ne 7.1!
5.Restart it again.
Good Luck!
:D
iansfan
Registered users: beanboy89, Google [Bot], Yahoo [Bot]
