98se Trouble
98se Trouble
Postby TUBA4 » Sat 30 Aug, 2003 1:40 pm
I would like to reinstall 98se over the existing but don't know if that will destroy everything that's already there. My 98se is unable to restore damaged files & i'm sure there are many. I'm not too swift with PCs. I have only a few programs installed of which IE5.5sp2, Netsc v4.7, Quicken, CD burner, a map program to name a few. However i have about 500 favs between IE & Netsc & hundreds of emails many of which are priceless.
It would be great if someone would be able & willing to post instructions for me on how to proceed from here. I would be truly greatful.
Thanx Y'all, TUBA4
UserAgent: Mozilla/4.79 [en]C-CCK-MCD NSCPCD479 (Win98; U)
TUBA4
Postby Edward » Sat 30 Aug, 2003 1:44 pm
In the past, I have reinstalled 98 SE over itself (without reformatting the hard drive), and it left everything already installed, as it was, afterwards.
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Linux 2.4.20-4GB i586) Opera 7.11 [en]
Re: 98se Trouble
Postby Fulvio » Sat 30 Aug, 2003 9:14 pm
TUBA4 wrote:I would like to reinstall 98se over the existing but don't know if that will destroy everything that's already there. My 98se is unable to restore damaged files & i'm sure there are many. I'm not too swift with PCs. I have only a few programs installed of which IE5.5sp2, Netsc v4.7, Quicken, CD burner, a map program to name a few. However i have about 500 favs between IE & Netsc & hundreds of emails many of which are priceless.
Thanx Y'all, TUBA4
You could always do a backup of your fav/bookmarks on a floppy.
Postby Phoenix21692 » Thu 18 Sep, 2003 6:28 pm
If you're still having trouble, it is possible to do a clean install of Windows 98 SE without having to bork the entire hard drive. So try this: boot up with a Windows 98 Boot disk and make sure it has the necessary CD-ROM drivers. Go to your C: drive and move all of the bootfiles to another location. Then using the CD, do a clean install of Windows 98 SE into another directory (e.g. Win98). After that, you should be able to start up in the Windows GUI once again and get everything salvaged in time. Hopefully, this should work especially when you have many files on the hard drive
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0; Q312461)
Phoenix21692
Postby Mandrake » Thu 18 Sep, 2003 8:14 pm
Why would you do that? Just do as Ed suggested, or put the hard disk in another computer and retrieve your data.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.0; en-US; rv:1.1a) Gecko/20020611
Postby Phoenix21692 » Fri 19 Sep, 2003 12:09 am
I would do that because if you have a clean install of Windows98 it's more stable than the overlay install, even though you have to reinstall the progams. It is also another method too, although it's just more complicated.
Now, if you're a user of the Windows 98SE Upgrade and you cannot boot into Windows, you'll have to move the bootfiles and install Windows 98FE and then upgrade it to Windows 98SE again for a clean install. I should've stated that the my method was intended for Win98SE Upgrade or OEM CD users who have trouble with booting into Windows. Sorry about the confusion.
Phoenix21692
