7.1 won't open
7.1 won't open
Postby Fran » Thu 11 Sep, 2003 3:41 pm
I am running Windows 98SE, 186 M RAM, lots of hard drive.
I have installed, uninstalled, reinstalled Netscape 7.1 several times but can't get it to open. The icons appears on the desktop but after it loads RealPlayer nothing else happens. When I click on the desktop icon, or even through Explore and clicking on the .exe file, the program won't open.
I also have 7.02 which works fine.
Can anyone suggest a solution to my problem? I'll try anything as I really want to try 7.1.
Any help appreciated,
Fran
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.0.2) Gecko/20030208 Netscape/7.02
Fran
Postby Alice » Tue 16 Sep, 2003 9:53 pm
I looked at your earlier post on this same problem here:
http://sillydog.org/forum/viewtopic.php ... highlight=
In situations where Netscape 7.1 will do nothing at all, you need to
-UNinstall Netscape using Add/Remove Programs
-reboot
-Delete of all leftover folders including:
~\Program Files\Common Files\mozilla.org (which contains the GRE folder) and
~\Program Files\Netscape\Netscape (assuming that's the install directory)
-delete associated registry entries
-Reinstall Netscape 7.1 and create a new profile
Before doing the above you may wish to re-download Netscape 7.1 to make sure you have a good installation file.
See this page for details
http://home.att.net/~cherokee67/ns71startupnot.html
UserAgent: Mozilla/5.0 (Windows; U; Win95; en-US; rv:1.0.1) Gecko/20020826
Postby Fran » Wed 17 Sep, 2003 10:17 am
Thanks I'll give that a try.
Fran
Fran
